Installing Stance Coils Today!
Old May 26, 2011 | 02:08 AM
matt638's Avatar
how low did you set them?
Old May 26, 2011 | 02:09 AM
BooSSted's Avatar
Originally Posted by Omnigear
if your totaly lost call stance support during normal workin hrs =p
they r helpful ^_^
Talked to them today. Sent him an e-mail of how I had everything installed as he requested. He said he'd call me right back. An hour later I called back because I didn't hear from him, he was gone....
Not the way its been described here.... I'll update tomorrow
Old May 26, 2011 | 03:09 PM
08ssedan's Avatar
Subd
Old May 26, 2011 | 03:12 PM
BooSSted's Avatar
Pull it all out today and fucked with it a little more. Ran out of time though and threw the stock pieces back in until I have a full day to work at it.
Can someone show me a pic of the stances installed with the wheel off? i want to see roughly how your struts and shocks are setup so I know if I am in the right area..
Old May 26, 2011 | 03:15 PM
dayhoff35's Avatar
in for pics
Old May 26, 2011 | 06:08 PM
ls1fbody's Avatar
Haz l33t wheelz.
Heres my fronts. Not that it helps much, mine has only 2 lockrings, vs the 3 yours should have.
Old May 26, 2011 | 06:19 PM
Omnigear's Avatar
did you try following the instructions we posted?
Old May 26, 2011 | 09:27 PM
BooSSted's Avatar
Yeah, I don't think my sleeve is spun up that far.
So tell me if I got this right. With the strut out of the car, you turn the top lock ring up until it securely holds the spring in place. Then you spin the strut body up to the desired height?
I've never seen a set of coil overs like this before. All the ones I have installed in the past were just a solid strut with the adjustable coil...
and with the back, I just up the rear arm until there is pressure holding the spring in place and then I bolt on the strut?
I didn't have a lot of time to work on it today so i just threw the stockers back in.
Old May 26, 2011 | 09:50 PM
ls1fbody's Avatar
Haz l33t wheelz.
Yup, right on both counts.
Height on the front is adjusted independently from the spring pre-load.
Old May 26, 2011 | 09:58 PM
BooSSted's Avatar
Ok cool. I'll give it a try again on the weekend. I knew something wasn't right because it rode BAD!
Old May 29, 2011 | 12:56 AM
  #36
BooSSted's Avatar
Got them installed again today. Front are perfect now, but the rears are still banging when I go over bumps. How do you guys have your rears setup? Bump stop removed? etc..
Old May 30, 2011 | 01:25 AM
  #37
dandaman15's Avatar
I set the springs and everything in first. Then with a jack I lifted up the twist beam untill the springs were seated on the top. Bolted the strut in with the top mount hole first, then I twisted the lower mount untill it was as close as I could get it to the rear bolt hole on the twist beam. THen I bolted the rear strut in, and tightened everything down. Rides really good, and I dont hear any weird noises, squeaks, or rattles yet.
Old May 30, 2011 | 11:18 AM
  #38
BooSSted's Avatar
Are yours at full low? Mine are in the rear and they sound like they are bottoming out over bumps. Just wondering if anyone else has that problem and if they modified anything to give the springs more travel before bottoming out.
I installed them the same way you described.
Old May 30, 2011 | 11:55 AM
  #39
ls1fbody's Avatar
Haz l33t wheelz.
My bump stops aren't cut, or removed. Leave them in. They protect the suspension at its extreme limit, and no matter how much you lower the car, the suspension still has a limit.
How fast are you hitting these bumps? lol, they shouldn't be bottoming out all the time. Lowered cars need to be driven carefully, i'm sure you know
Old May 30, 2011 | 11:56 AM
  #40
dandaman15's Avatar
Mine are all the way down with the collars in. I plan to take them out soon though. I dont hear anything and Ive been trying to hit **** to make sure there are no ill sounds lol.
Old May 30, 2011 | 12:08 PM
  #41
BooSSted's Avatar
Ya, I'm going slow. Like backing out of my driveway slow, haha. I took the bump stops out because Dave at Stance told me to. He also said there was something in the rears that needed to be cut out along with the bump stops. I think he was referring to the plastic mounts that hold the springs in place. I wasn't comfortable with that advise so I left them as is.
I'll throw the bump stops back in and see if that helps. But it's still going to bottom out... no?
Old May 30, 2011 | 03:46 PM
  #42
ronn's Avatar
I'm not familiar with these..but...seems like there has to be a ride height were you will not bottom. I think you want the springs in slightly tight at full droop..then you set the height.
I mean..it seems pretty basic..am I missing something?
Old May 30, 2011 | 11:08 PM
  #43
BooSSted's Avatar
No, that's right. That's what I did when I installed mine. I just think it is too low. There is only about 2" of suspension travel back there now.
The fronts are at full low and they haven't come close to bottoming out, they're nice and solid but still ride fairly smooth.
Old May 30, 2011 | 11:31 PM
  #44
ronn's Avatar
I don't have coil overs...but I found this pic of Pedder coil overs on car. This is at full droop. Looks like spring has some clearance here.
Here are k Sports on the car at droop...springs are also loose in the perch here:
Old May 30, 2011 | 11:39 PM
  #45
BooSSted's Avatar
That spring is way bigger than Stance's
Old May 30, 2011 | 11:52 PM
  #46
BooSSted's Avatar
Sorry, that's a huge pic, haha
Old May 30, 2011 | 11:59 PM
  #47
DOMDOTCOM's Avatar
MADE STANCE COOL
about goddamn time! Now stance your **** or die
Old May 31, 2011 | 12:19 AM
  #48
BooSSted's Avatar
Old May 31, 2011 | 12:21 AM
  #49
DOMDOTCOM's Avatar
MADE STANCE COOL
bahahhahaha
biniecki
Oct 25, 2015 02:23 PM
dennis69
Oct 20, 2015 04:49 PM
no_ss
Oct 18, 2015 11:58 PM
justinchinn
Oct 2, 2015 12:18 PM
OrangeCoba
Oct 1, 2015 10:00 PM
