intermediate shaft slight play
Old Sep 17, 2014 | 05:35 PM
happygil0303's Avatar
I've had a knocking noise that would speed up with acceleration on the passenger side. Since I replaced pretty much everything but the axle I'm almost certain its the cv joints. My question is while getting ready to pull the axle I found slight play in the intermidiate shaft on both the lsd side and axle side. It seems to be only slight play like you can feel the bearing shifting. Its not leaking any fluid or anything. Is this normal?
Old Sep 18, 2014 | 12:39 PM
Chevrolet Cust Svc's Avatar
Hi happygil0303,
We understand you've had some trouble with a knocking noise while accelerating and our apologies for any frustration this has caused. Although we're unable to technically advise towards a fix, we're happy to look further into this matter, or connect you with a local service team that can assist. Good luck with repairing everything and if you have any further questions just send us your VIN.
Amber N.
Chevrolet Customer Care
Old Sep 18, 2014 | 12:49 PM
Bass_Waves's Avatar
Yeah ur pin is about to shoot out and pop a hole in ur trans. Happened to me. Same exact description. Put a new axle in and it lasted 2 weeks before the diff pin shot out .
It may be the same for u or not. This happened to mines with the same complaint ur having. Gl though.
Old Sep 18, 2014 | 04:18 PM
Well I pulled the axle and I have a question. I took some pictures so hopefully somebody would chime in. The inner part of the axle where the ribs are that go into the intermidiate shaft there is some sought of clip that I'm not sure is broken or not. I really can't tell. Is this gap suppose to be present in this clip?
Old Sep 18, 2014 | 04:22 PM
I can't figure out how to add images lol
Old Sep 18, 2014 | 04:41 PM
http://oi57.tinypic.com/2csjwjd.jpg
http://oi61.tinypic.com/2i2bhc9.jpg
Old Sep 18, 2014 | 04:51 PM
Bass_Waves's Avatar
Yup normal. New axle comes with a new clip. Don't remove em. They secure the axle in the trans/shaft.
bigdeertz
Nov 17, 2016 09:41 AM
deviance
Nov 24, 2015 05:51 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
justinchinn
Oct 2, 2015 12:18 PM
