Just installed sportlines, quick question....
Old Aug 23, 2008 | 08:31 AM
lowrd03vr6's Avatar
So a few days a go I had my Sportlines installed and they ride great, and look even better, however, last night I was riding around and heard a weird noise coming from the rear of the car. Every time I hit a decent sized bump, there would be like a squeaking / squoosh type sound.
Has anyone ever had this before, or anyone have any idea what it may be?
Old Aug 23, 2008 | 08:50 AM
glen229's Avatar
hmmmmm not on mine and ive had them since the car had 500 miles ... granted its only got 4000 now but ive never heard that noise... did u leave those "clear" rubber sleeves on the rear springs?
Old Aug 23, 2008 | 09:03 AM
cobaltsscoupe's Avatar
have had mine for 2 years no problems never had any noise but a big plus in the way ti handles
rear struts blown out?
Old Aug 23, 2008 | 09:11 AM
ls1fbody's Avatar
Haz l33t wheelz.
those clear rubber things are supposed to protect the springs right?
Old Aug 23, 2008 | 09:21 AM
D4u2s0t's Avatar
they stop the "squeak" that can be heard when the springs touch under pressure.
i would make sure everything is tight, the spring is fully seated, and in the right way.
Old Aug 23, 2008 | 09:47 AM
lowrd03vr6's Avatar
Yeah, I left the sleeves on the springs.
I dont think so and I certainly hope not, they only have 8000 on them.
I am starting to wonder if maybe I didnt take enough off of the bump stops???
Last edited by lowrd03vr6; Aug 23, 2008 at 09:47 AM. Reason: Automerged Doublepost
Old Aug 23, 2008 | 09:54 AM
D4u2s0t's Avatar
that would make more of a thump than a squeak. look at my above post.
Old Aug 23, 2008 | 10:05 AM
glen229's Avatar
we diont have rear struts
Old Aug 24, 2008 | 12:05 PM
on the install they tell you to use the rubber from on your new springs that could be the noise you hear
Old Aug 24, 2008 | 12:10 PM
dman090's Avatar
my best bet it would be the rear shocks
search ebay for sum FE5 shocks or you can get the koni yellows
Old Aug 24, 2008 | 12:19 PM
116Fanatic's Avatar
I have the SAME problem since the day i installed my sportlines and I could never figure it out. I checked the seating and everthing...never checked the rubber on the spring though? Could be a shock too cuz its only on the rear right side...
Old Aug 25, 2008 | 09:59 AM
lowrd03vr6's Avatar
Everything is tight and sully seated.
What is the rubber that you are talking about?
Last edited by lowrd03vr6; Aug 25, 2008 at 09:59 AM. Reason: Automerged Doublepost
Old Aug 25, 2008 | 10:01 AM
BigTizzle903's Avatar
check that bolt that holds the rear strut on. mine kept coming loose until i lock tited it. made a similar noise
Old Aug 25, 2008 | 10:06 AM
D4u2s0t's Avatar
after taking a 2nd look at the first post it just may be the sound of the rear shock compressing. when you go over bumps, you will hear a rush of air as the shocks compress/decompress.
Old Aug 25, 2008 | 01:35 PM
lowrd03vr6's Avatar
Would I have heard this with the stock springs? This is the first I have noticed it.
So I just went out for lunch, and I was driving with the radio off to see if I could better tell where this noise is coming from. I was unable to figure that out, but I did notice that there is also a squeaking noise when there is a flex in the body of the car, like when making a turn onto a street that is at a higher incline then the street you turned off of. Kinda confusing, but thats the only way I could think to explain it.
Last edited by lowrd03vr6; Aug 25, 2008 at 01:35 PM. Reason: Automerged Doublepost
Old Aug 25, 2008 | 02:07 PM
D4u2s0t's Avatar
a very common thing is to hear, see, or even feel things that "weren't there" before you did your install. what happens, is that after you install something, you're more aware of any sounds or feelings that happen, and you automatically assume it has something to do with the parts.
Old Aug 25, 2008 | 02:12 PM
lowrd03vr6's Avatar
Haha, I hate that.
Old Aug 25, 2008 | 02:27 PM
D4u2s0t's Avatar
i would just check to make sure that eveyrthing was installed properly, and everything is tight.
Old Aug 25, 2008 | 02:33 PM
lowrd03vr6's Avatar
Well hopefully I can get it checked out this week sometime. I am still kinda thinking the bump stops may not have been cut short enough. Now that I think about it, we didnt cut the fron ones at all, could this create a problem?
Old Aug 25, 2008 | 03:17 PM
D4u2s0t's Avatar
i've done springs on many cobalts, never cut the front, and never had an issue. I always cut the back though, if you're looking at it the way it sits you cut to the first ridge usually, depending on the springs. that should be in the instructions though.
Old Aug 25, 2008 | 09:19 PM
BMC2U's Avatar
Mine squeaks from the right rear also after installing springs. It only does it at slow crawling speeds such as going into a driveway, etc.
Old Aug 25, 2008 | 09:20 PM
WhiteSSBalt's Avatar
Not a Sebring
I have 49k on my stock struts, the car has been lowered on Sportlines almost 2 years, and I carpool with up to 5 people in my car at a time, and my stock struts are still holding up, so I doubt its his struts, lol.
Old Aug 26, 2008 | 07:18 AM
lowrd03vr6's Avatar
I really don't think it is the struts, they only have like 8k on them. I need to get with Steve and see if we can figure out what this is.
Old Aug 30, 2008 | 06:22 PM
lowrd03vr6's Avatar
So today I went and got my car aligned and I also had the shop that did the alignment look over the springs to make sure they were installed correctly and sure enough they were. I decided when I got home to jack the car up and make sure everything was tight in the rear, since that is where the noise is coming from, and everything is good, but I still have the squeaking noise.
The noise is only coming from the passenger side on the rear, so while it was in the air, I pushed upwards under the spring to make it compress and it made the sound. It seems that it is happening when the spring is compressing and the coils are rubbing together, even though I did leave the plastic sleeves on to prevent this.
Has anyone had the same issue, or does anyone have any ideas on how to stop this?
