Knocking noise. All new parts. Video
Old Oct 1, 2016 | 10:24 AM
tuned08ss's Avatar
Hey guys, got a video of this noise I been hearing for a while now. Need help figuring out what it is. Some history of the car below:
2008 lnf, new axles, brakes, struts, shocks, and springs. All done in the last 3k.
Had a new trans put in in 2014 and had ottp trans mounts, control arm bushings, ball joints, and tie rods done then too.
I'm leaning towards cabs but I'm thinking how did my current ones only last ~15k. Haven't done sway bar end links. You guys let me know what u think
Old Oct 1, 2016 | 12:13 PM
Doesnt sound like cabs. Did you do the inner tie rods as well?
Old Oct 1, 2016 | 12:55 PM
My OTTP cabs only lasted 1yr so yeah worth checking them but not saying that's your noise
Old Oct 1, 2016 | 02:23 PM
tuned08ss's Avatar
I had the inner and outer done. This noise has been there before all installed parts.
Old Oct 1, 2016 | 02:45 PM
63 Nova SS's Avatar
Can't hear it real well, does it do it over bumps, elevation changes, when you take off from a stoplight, around tight curves? Louder when you get on it? Do you have any torque steer under wot?
Old Oct 1, 2016 | 03:07 PM
tuned08ss's Avatar
Makes noise when I take off and when I'm almost coming to a complete stop. Don't really hear it over bumps, but turns I do. Doesn't have to be at full lock. So to reiterate, I hear the knock during light accel/decel, any turn angle and more so when reversing.
Old Oct 1, 2016 | 03:28 PM
cluelessk's Avatar
Sounds like it could be strut mounts. Should of been changed with the struts though.
Did this start before or after the new parts?
Old Oct 1, 2016 | 04:11 PM
tuned08ss's Avatar
Before. Is there any way to check if it's the strut mounts?
Old Oct 2, 2016 | 01:25 PM
tuned08ss's Avatar
I'm really thinking it sounds like an engine or trans mount. When I push in the clutch to come to a stop it seems like a lot of movement coming from up front and the noise is present.
Old Oct 2, 2016 | 03:22 PM
63 Nova SS's Avatar
There have been some Ottp trans mounts that have failed. May check that front trans mount bushing.
Old Oct 2, 2016 | 04:43 PM
tuned08ss's Avatar
Thanks for the help guys. I'll take a look and get back to you
Old Oct 3, 2016 | 11:46 AM
tuned08ss's Avatar
So I checked the front trans mount. Looks good to me
Attached Thumbnails img_20161003_085217.jpg   img_20161003_084958.jpg   img_20161003_085241.jpg
Old Oct 3, 2016 | 02:00 PM
tuned08ss's Avatar
It's getting worse every day now. Does anyone know how many motor mounts are on these lnf's and where they're located? I see the one up top but don't know where the others are. Also, I will have a video up from outside for you guys to hear in a little bit.
Old Oct 3, 2016 | 03:29 PM
mzspd's Avatar
Kind of shot in the dark but what about Intermediate Steering Shaft? My gf's is going bad (base model cobalt) and I am beginning to think mine is (09 LNF 130km). She gets a bad knocking when braking and it sounds like a rattle if you jiggle the wheel under braking.
Old Oct 3, 2016 | 04:07 PM
tuned08ss's Avatar
Here is a video from outside the car. Idk how to add this to my opening post.
Old Oct 3, 2016 | 04:12 PM
mzspd's Avatar
Okay that is much better.. That sounds like a ball joint, my truck did the same noise and symptom like that.
Old Oct 3, 2016 | 04:45 PM
63 Nova SS's Avatar
The intermediate shafts do rust and fall apart if exposed to salt. If that's it you should feel a little dead zone in your car going down the road when you turn your wheel side to side.
Old Nov 19, 2016 | 08:03 AM
tuned08ss's Avatar
The noise ended up being a ball joint. The problem now is that my steering knuckle is cracked where the ball joint meets. The part is $251 from the dealer and takes 5-7 days to get here. Couldn't find it anywhere locally.
geofery_sousa
Wheels and Tires
Aug 22, 2016 01:48 PM
jamie_0192
Canadian North East
Aug 19, 2016 08:21 AM
hopewillfall
Jul 23, 2016 01:40 AM
T-Man
Jul 13, 2016 08:27 PM
Levi381
Jul 11, 2016 07:55 PM
