koni front strut inserts
Old Mar 3, 2015 | 04:34 PM
Hey emp i have a few questions for you on the fronts
Old Mar 3, 2015 | 05:01 PM
So thats what i have and im going to install tomorrow. My question is if that black sleeve goes there? Also on the black bolt and the two washers it seems its the black one then the other one but is that one supposed to be like the second or the third pic? So i guees i can say with the curve going up or going down also i dont see where you placed your clear plastic but that can only go in one place that i can see did you put it in?
Old Mar 3, 2015 | 05:23 PM
Ohh also im supposed to pull the koni all the way down huh then use the black bolt and torque to 55ftlb?
Old Mar 3, 2015 | 06:34 PM
EmperorJJ1's Avatar
Its been a while since i did mine but the top set is supposed to go on the top and the bottom to the bottom. If i remember correctly i did it like the last pic but im not 100% sure. It should say in the instructions though. Black sleeve i used to cover from the koni to the stock piece. Heres a pic of what mine looked like when they were done.
Old Mar 3, 2015 | 06:42 PM
Yeah im kinda figuring it out but the instructions are useless lol just pics and they suck im having a bit of trouble getting the insert down to where the bolt from koni will reach well at least with spacers it comes with
Old Mar 3, 2015 | 06:46 PM
EmperorJJ1's Avatar
spacers?
what length did u cut them if i remember correctly we cut it to the length posted on some how to on here vs what the instructions said
Old Mar 3, 2015 | 08:15 PM
Well im talking about the black nut and those other 2 the ones on the last pic if i put them on i cant get the thread but if i dont use them i can but i just need to get a good grip on the housing because i cant turn and hold the housibg at the same time lol in still in the process of inserting them into the housing
And well my biggest question is if the black washer goes in first into the bolt or the other one goes in first
Old Mar 3, 2015 | 08:34 PM
That answers my question lol
Ok the other question i got the housing from powell and he send me a bolt spacer and washer to pull the koni inside the housing the only question i have is is the koni supposed to go all the way down?
Old Mar 3, 2015 | 10:31 PM
96S1's Avatar
Yes. Although I have not done the Koni insert on the Balt yet, when I did the Koni's on my Z24 12+ years ago, it was the same. You are basically bottoming the Koni insert inside the stock housing.
Basically used the bolt to draw the insert all the way to the bottom, removed and put washers in place, then torque to spec.
Old Mar 3, 2015 | 10:41 PM
Nice thanks that helps alot. Plus im sure it will help someone else since the koni thread has no pics anymore. Only questions is how to torque the bottom bolt if it uses a hex key or whatever its called
Old Mar 3, 2015 | 10:48 PM
  #36
96S1's Avatar
Hex Bit Socket Set
Old Mar 3, 2015 | 10:53 PM
  #37
There we go lol hopefully they have those at school. Im sure they do but we will see tomorrow thanks
Old Mar 4, 2015 | 02:46 PM
  #38
Yup got them in one gave me a bit of a hard time trying to retract it into the housing but it all worked out and the ride is so much better
bigdeertz
Nov 17, 2016 09:41 AM
SSLOW06
Oct 1, 2015 07:21 PM
Tupp
Sep 30, 2015 08:18 PM
n20saturn
Sep 30, 2015 12:26 AM
