Koni Install?
Old Mar 8, 2011 | 01:48 AM
StrongIslandBalter's Avatar
Koni Install?
I was on zzps site and apparantly the front struts are hard to install wtf?lol and the instructions make it seem like it wouldnt be a clean install? food for though or .02 appreciated
Old Mar 8, 2011 | 01:51 AM
SlowBalt_06's Avatar
better off with getting stock tc struts
Old Mar 8, 2011 | 01:56 AM
Mr.N00bLaR's Avatar
Once upon a time... we were given a how-to section. Then the gods blessed us with a how-to for koni front inserts.
hahaha jp man, but seriously:
https://www.cobaltss.net/forums/how-...-struts-57977/
It would be much easier to get sstc equipment, I have them and like them as do most.
Old Mar 8, 2011 | 02:47 AM
well idk i feel like everybody has persuaded me to do that koni pedder combo over the megan coilovers :O(
Old Mar 8, 2011 | 12:51 PM
Wangspeed's Avatar
TC > cheap coilovers, but if you're running springs and a bar, Koni > TC.
The how to posted above is very good, although I would add that you may want to use a big pipe cutter instead of trying to saw the strut apart. A pipe cutter will leave you with a nice clean cut. Don't crush. Just spin it a bunch. Alternatively, you could use a sawzall with a fine tooth blade, or a good old hack saw. Whatever you do, you want to cut straight, not like the how-to where he hacked it up, and has to do a bunch of cleanup afterwards with a file. This means a Dremel probably isn't a great choice.
Old Mar 8, 2011 | 01:13 PM
AyrtonSenna's Avatar
To install the front konis, you have to destroy your stock struts
Old Mar 8, 2011 | 01:52 PM
scottherbert's Avatar
Wangspeed has it right! I bought a cheap pipe cutter from Home Depot (less than $10), I wrapped blue painter's tape around the strut first - which gave me a 'no-slip' surface, and it took about 5 minutes to have everything done without any hassle. Don't use anything other than a pipe cutter!!!
Scott
Solaris99
28
Mar 15, 2017 01:22 PM
dennis69
Oct 20, 2015 07:39 AM
justinchinn
Oct 2, 2015 12:18 PM
Delta coupe
Sep 30, 2015 08:11 AM
Bohb
Sep 27, 2015 09:11 PM
