lnf springs
Old Aug 9, 2013 | 02:05 PM
Avalanche687's Avatar
lnf springs
Would putting stock lnf springs on my 2.4l sedan do anything for me? Just wondering.
Old Aug 9, 2013 | 02:56 PM
chevygirl2006's Avatar
Probably not
Old Aug 9, 2013 | 02:59 PM
blueLNFftw's Avatar
Im wondering if the LSJ springs are different than the LNF springs.
Old Aug 9, 2013 | 03:01 PM
Sox-Fan's Avatar
Got Brakes?
They are.
Old Aug 9, 2013 | 03:03 PM
SalvageBaltSS's Avatar
They are. But not by much. After reading a little, lnf's are a little lower, but you cant tell a difference. I was going to put lnf's on my lsj, but got tenzo's .
Old Aug 9, 2013 | 03:04 PM
nobody2u's Avatar
The LNF springs are stiffer I believe.
Old Aug 9, 2013 | 03:05 PM
oh. Then im wrong lol. Sorry .
Old Aug 9, 2013 | 03:27 PM
So if I can get lnf springs really cheap should I?
Old Aug 9, 2013 | 03:30 PM
nobody2u's Avatar
Over the FE3, they are an improvement on handling, whether they are lower or not, I'm not sure. The question you have to ask yourself is, will you want lower or better handling ones in the future? Because if so, I wouldn't bother.
Old Aug 9, 2013 | 03:32 PM
Bad-A-SS's Avatar
I could get you a set fairly cheap pm me
Old Aug 9, 2013 | 03:36 PM
blueLNFftw's Avatar
What about struts and shock? LSJ versus LNF
Old Aug 9, 2013 | 03:41 PM
nobody2u's Avatar
Someone can correct me if I'm wrong, but nearly much all of the suspension between the LSJ and the LNF was either replaced or revised.
Old Aug 9, 2013 | 03:44 PM
I believe you are correct on this.
Sox-Fan's Avatar
Got Brakes?
lower control arm on LSJ steel, LNF aluminum. Bigger brakes on LNF. Believe the front sway bar is different. Springs are different, struts are too. Pretty sure the sway bar welded into the rear beam is different also.
Old Aug 9, 2013 | 03:49 PM
blueLNFftw's Avatar
Okay then. So LNF struts and shocks it is for me then.
Old Aug 14, 2013 | 05:49 PM
BLue NoTe's Avatar
Originally Posted by Sox-Fan
lower control arm on LSJ steel, LNF aluminum. Pretty sure the sway bar welded into the rear beam is different also.
Incorrect about arms, FE5 were both aluminum however the two are very slightly different, the LNFs have a larger ball joint, I think by 1 mm. Sway bars for LSJ are 24 front, 22 rear. LNF is much better at 23 front 24 rear. I got very good results from putting the LNF front sway on my LSJ, would love to pick up a rear beam as well.
Old Aug 14, 2013 | 05:55 PM
BLue NoTe's Avatar
LNF springs are lower than LSJ by I think 10 mm, don't know exact rates but John has said the LNF rears are progressive which is nice. The LNF dampers were tuned on the Nurburgring with the help of Opel who know how to make fast FWD cars. I think I read somewhere they changed the bump damping compared to the LSJs but the rebound is more or less the same. That said the Koni yellows are awesome for performance, seriously good
Old Aug 14, 2013 | 08:17 PM
QCbalt09's Avatar
I have a set of lnf and ksport springs but no fe5 struts. Just koni yellows, ill sell to you cheap if your looking still. just pm me
Old Aug 14, 2013 | 08:22 PM
blueLNFftw's Avatar
How much for the Koni's?
Old Aug 14, 2013 | 09:39 PM
QCbalt09's Avatar
I'll pm you.
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
Jan 12, 2016 12:01 AM
Oct 13, 2015 09:32 PM
patooyee
Oct 1, 2015 01:07 PM
