Lowering kit question
Old Oct 22, 2012 | 03:07 PM
1LowLS's Avatar
I know.Me being one of them lol,which I stated that and what you said in a previous post.
Old Oct 22, 2012 | 03:32 PM
Crav3's Avatar
You can get some wider tires too
I have 215/45/17 tires and they raised my car 1/2 in when i installed them compared to my 15s
Old Oct 22, 2012 | 03:34 PM
AyrtonSenna's Avatar
Oh. I've seen alot of people slammed on stock wheels and it didn't do that.
Just gave my opinion. Even on my TC i thought the same and i got wheel spacers. But if it's fine for you, i guess it's ok
Old Oct 22, 2012 | 03:40 PM
1LowLS's Avatar
I have spacers on my 17's currently.Makes a big difference.
Old Oct 22, 2012 | 06:23 PM
G5_Stuntin's Avatar
If I get something like sportlines do I have to upgrade other things like my struts since it will be such a low drop?
Old Oct 22, 2012 | 06:39 PM
chevygirl2006's Avatar
The width of the tire doesn't make your car sit higher. My tires are 245/45/17
Old Oct 22, 2012 | 06:43 PM
1LowLS's Avatar
No you don't but ride quality will suffer.But it's not bad
Depends actually.Going from a 225/45/17 to a 245/45/17 is a taller tire.Easiest way to break down the metric tire size.
225 is width in MM.45 is 45% of the width and obviously 17 is Rim diameter.
Old Oct 22, 2012 | 06:45 PM
I have cm springs and they are about as low as sportlines and I still have stock struts and shocks and they have 91k miles
Old Oct 22, 2012 | 06:46 PM
How is 245/45/17 taller than 225/45/17? Isn't the only difference in the tire the width?
Old Oct 22, 2012 | 06:49 PM
1LowLS's Avatar
245 is 245mm wide and 45 is 45% of the width.If you increase the width with the same profile.the profile increases as well.look at it this way.your sidewall is 45% of 225.now your sidewall is 45% of 245.Make sense?
Old Oct 22, 2012 | 06:51 PM
  #36
The 45 is the side wall isn't it? Lol tires confuse me sorry
Old Oct 22, 2012 | 07:06 PM
  #37
1LowLS's Avatar
Yes 45 is the sidewall as 245 is your width.45 dictates 45% of your 245 wide.If you were to get a 225/45.your sidewall is now 45% of 225 so it gets smaller in diameter
Old Oct 22, 2012 | 08:20 PM
  #38
07cobaltLScoupe's Avatar
easiest way to explain it is that the 45 is a ratio of width to sidewall. if you go wider with the same ratio it also goes taller, smaller width with same ratio the tire is shorter...
now here's 2 pics of my car from about the same angle just different distances but you can see the difference, the first is on Eibach Pro-Kit springs and the second is on Megan Racing coilovers... i'd love to get these same wheels in 17's but that most likely won't happen while this is my DD
Old Oct 22, 2012 | 09:37 PM
  #39
Crav3's Avatar
Coils looks nice! And yes wider makes it a bit taller lol
ineedacobaltss
Nov 7, 2015 02:25 PM
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 04:49 PM
