Megan vs. Stance vs. Pedders Coilovers
The delrin front CAB needs to be reamed out. We took a big bolt, cut the head off, slotted it, and folded a piece of sandpaper into the slot. Then we put that into an air gun, and worked it up and down the delrin bushing to make the bow tie pin a perfect fit.
NT01 needs tons of camber. I'm finding that -2.0 is not enough. I'm a little annoyed with them actually. Anything under 37 hot, and they want to roll halfway over onto the sidewalls. I run them around 40-42 hot. I'm going to try increasing camber for the next event. If you're driving typical student pace, -2.0 will probably make you very happy. If you start to really push the limits of you and the car, I find that it understeers in the slow stuff. Awesome in faster turns though.
If you go to the track at all, you should get the hardcore bar.
Or they just don't have the drop ??
I've always heard Stance brings in the most low... I just put pedders on my LNF with stock struts and shocks and love how it handles though I wish the rear was another 1/2-3/4 inch lower. Still looks killer though, especially over stock. Much nicer ride too.
