Monroe shocks and struts?
Old Mar 27, 2013 | 12:43 AM
Nuke's Avatar
Will Excel G2 stuts/shocks be good with sport lines? Also would I need to upgrade to the MOOG endlinks?
Old Mar 27, 2013 | 07:09 AM
Powell Race Parts's Avatar
you will probably need some new end links if they are corroded in place. Good luck with your choice of springs and struts.
Old Mar 27, 2013 | 07:57 AM
JapEatr's Avatar
South Central *********
This is you first post Nuke? Nice!
Old Mar 27, 2013 | 08:23 AM
SS89's Avatar
I installed a set of front Monroe shocks from Canadian Tire last weekend on my SS/SC. While I was installing my SSC springs I decided to change the front links as they were making noise. Well I found out why, my passenger stock shock had a busted bracket. I decided to change the two front shocks. So far so good, they're holding. I inspected them last night and they're good. Not the best shocks you can buy for the money but it's an exact replacement.
And by the way I'm super satisfied with SSC springs, my car now has 1 1/2 fingers between the front tire and fender and 2 fingers between the rear tire and fender. Ride is almost OEM smooth too!
Old Mar 27, 2013 | 11:43 AM
Nuke's Avatar
It is! I mainly ask only for opinions, but I look around here quite a bit. Along with G5club!
Old Mar 27, 2013 | 01:06 PM
09CobaltSport's Avatar
gmpartsdirect.com has stock replacement 08+ fe5 struts, shocks, and springs. they are the same part numbers as those on CED but considerably cheaper. wouldn't this be the way to go? i can't imagine anything like monroe or whatever else would be any better, especially considering how much more they cost.
ZZP's website makes it sound like the KYBs are designed to perform exactly like the stock ones, but they're much more expensive. maybe i'm missing something, but it sounds like stock replacements from gmpartsdirect.com would be the best deal, unless you're actually looking for increased performance.
Old Mar 27, 2013 | 01:42 PM
SS89's Avatar
Monroes in the front aren't that bad, I'm strongly considering Koni yellows in the rear though.
Old Mar 27, 2013 | 02:12 PM
Gelladuga69's Avatar
Have you factored in shipping? They have outrageous shipping charges. Try it and check though.
They're really slow with shipping as well. Took me 2 weeks to get something from them.
Old Mar 27, 2013 | 02:24 PM
well i should have known it was too good to be true.
example:
FE5 strut RH: #19181631
gmpartsdirect: $84 + $21 shipping = $105
CED: $92 + $15 shipping = $107
negligible difference.
are KYBs any better than stock? i guess they're about the same price
Old Mar 27, 2013 | 02:43 PM
CED sells a whole kit for that stuff too, saving you more money.
I know nothing about KYBs.
bigdeertz
Nov 17, 2016 09:41 AM
DANRICKARD
Oct 1, 2015 12:08 AM
Tupp
Sep 30, 2015 08:18 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
