Moog swaybar endlinks
I'm looking into getting some new swaybar endlinks (broke one a few days ago
) and when I was shopping around for the best price, I noticed that there was an option for the Moog FE5 Standard and Moog FE5 for cars with 'Sport Suspension' or something along those lines.. both of these are for the SS.
What is the difference? Is one shorter than the other?
I was just confused because I thought all SS's had the same suspension.. FE5. But there are two FE5 'sub category' options.
I'm looking to replace the endlinks on my base model, so which ones should I get?
Thanks!
Thanks!
Thanks!
Thanks!
just read you have a base model. im not sure if the moog will fit if you have a base model though. i think you have fe1
Thanks!
Thanks!
Last edited by GM COBALT SC SS; May 22, 2010 at 11:42 PM. Reason: Automerged Doublepost
My car is lowered about 2.5ish inches, so I need the shorter FE5 links. The reason I snapped my first set was because I didn't replace them after my drop, and.. well.. snap.. haha.
I'm just curious why there are two different FE5 link options.
its not two different fe5. one is fe3 sport or ss and one is fe5 sc ss
When I went to Advanced Auto their computer said 'Moog FE5 for Sport Suspension' and 'Moog FE5 for Standard Suspension' (Something along those lines.. like I said)
That's why I was confused. They both definitely said FE5.. I checked and double checked and then triple checked haha.
endlinks
the best adj ones are powergrid..
check them out at www.newedgeperformance.com is where i got mine
Ryan
http://www.newedgeperformance.com/po...ntswaybar.aspx
Ryan
Last edited by RDKDESIGNSG5; May 23, 2010 at 08:20 PM. Reason: Automerged Doublepost
Sorry, but what does this do? I am replacing my FE3's with FE5's to go with my Sportlines. I was suggested to do this and the poly mounts.. How will these help me? And easy install??
the endlinks are a great suspension addition and i got a weird noise similar to yours but to me sounds more like a rubbing noise. im thinking its the sway bar bushings as there is no rubbing marks anywhere on my vehicle.
