Moog swaybar endlinks
That's what I was thinking if I buy a set but I plan on staying with my stock shocks and struts until they wear out before I switch in a set of FE5 ones, think that would make a difference in the short term?
Ok so I've got an 08 sport with the FE3 setup. I'm going to be lowering the car this spring around 1.5 to 2 inches all around. Will a set of FE5 endlinks, moog or powergrid bolt right up or do I need to set them up?
^^Also above posted depending on what I find out I'd be interested in your links if your still selling them or they are still for sale.
I have zero regrets buying them and would buy them again.
Yeah dude, in all honesty, I have no clue what they do "better" than stock. I just know that the guy working on my car suggested I get them while I was getting steering rack spacers put on (in which never came)..
[QUOTE=CordiaDOHC;5481959]Yes they will bolt up fine. Just remove your FE3's and put your FE5s on. Im also an 08 Sport on stock shocks and struts but with Eibach pro springs.
Thank you very much, that pretty much sealed the deal for me. Oh and nice looking N/A by the way
Yeah I keep hearing that they will improve your car but nobody can really tell how or by how much. Either way I'm doing it lol.
[QUOTE=csa1982;5483002]Thanks!
I just got the Eibach Sportline springs for my FE3 setup. They drop the front 1" and the rear 1.3", The Moog FE5s look to be 1" shorter than stock FE3s. My guess is this will help keep everything in line. Everything unbolted except for the front stock FE3 swaybar end links.I can't seem to find a way to keep the bolt from turning when I wrench the nut,Do you have to cut these off or what? Kind of an old thread so I won't hold my breath for an answer.
i know reviving an old thread, which MOOG links did you go with? I think mine are bad, and just wondered if the FE5's would fit a currently stock FE1 (lowering it later this year)
I know this is an old thread, but would there be any advantage to putting the fe5 sway bar links on a stock fe1 suspension? would the shorter bars be more beneficial or give better handling?
Back from the dead, again, but I'm looking at Rockauto and I see two different P/N's for the FE5 suspension. K750012 and K80252. Which one is the correct one, if it matters? And I'm on Sportlines.
MOOG Part # K750012 More Info 9.86" Center to Center
Frt Susp; Performance and Handling susp. (RPO code: FE5) $21.79
MOOG Part # K80252 More Info
Frt Susp; Exc. Performance and Handling susp. (RPO code: FE5) $26.79
Here is the link I searched through: 2005 CHEVROLET COBALT SS Stabilizer Bar Link
Edit: Just went over to Autozone.com and their Duralast (house brand name) had 2, one for FE5 (9.86" from center) and one for FE3, no length listed. Clears up some fog for me.
