need help adjusting coils
Hey, just looking for some help since its my first time adjusting my coilover since putting them on. I have the Stance GR+. I looked on their website, adjusted the lock ring 1\4" higher since it started on the bottom. Put the wheel back on and lowered, and no change. I guess im confused how they work and would appreciate some guidance and knowledge.
Here is the lock ring up a 1/4" from bottom
As soon as i lower it back down it sits onto the tire. What am i doing wrong? Lol
the only thing u adjusted was the length of the shock in the rear from the looks of the picture.
adjust ring on the perch where the spring sits
edit: turn the rings on the perch up about an inch and u will be fine
to get the preload, keep the top of the shock bolted and let it hang, jack up the axle to compress the springs and do that 1/4 thing to adjust the shock length to match the spring
something like that, then u can bolt the bottom of the shock back up and have a good day haha
a side question on the same kit: how to eliminate hard bounciness in the rear? I've turned the dampening down but it still bounces hard? should the shocks take up all the slack in the rear so the springs don't have slack when the axels down?
ill try to answer this, is the damper full stiff? and the shock should be adjusted to height of spring when compressed. 1/4 inch off from that to get it set right?
i went full stiff then backed it off 5 clicks should be close to the "sweet" spot. By compressed you mean full car weight or like like push up with a board and jack to take the slop out of the upper and lower spring mount?
enkei m52?
the rear is easy and this thread talks about it mostly
