Need help! (lowering)
i know this might have been posted before but, i just got my sportlines this week and wanted to know if a camber kit(shim) is needed for the rear. i know you use camber bolts for the front. also, ive seen posts where they say that kyb struts do not fit the pro-kit. is it the same for the sportlines?
also after lowering it take t to get and alingment and if you need a camber kit in the front they will let you know, but if its a good place they will be able to get it pretty true to spec
