Need help! (lowering)
Old May 7, 2010 | 01:29 AM
stwss's Avatar
i know this might have been posted before but, i just got my sportlines this week and wanted to know if a camber kit(shim) is needed for the rear. i know you use camber bolts for the front. also, ive seen posts where they say that kyb struts do not fit the pro-kit. is it the same for the sportlines?
Old May 7, 2010 | 01:49 AM
09turbo's Avatar
the rear is a tortion beam... its solid.
no camber....
as far as the springs... if your car is factory any springs for your car will fit.
Old May 7, 2010 | 02:07 AM
stwss's Avatar
ok. thanks for the help
Old May 7, 2010 | 02:16 AM
OneCOLDBIZL272's Avatar
also after lowering it take t to get and alingment and if you need a camber kit in the front they will let you know, but if its a good place they will be able to get it pretty true to spec
ineedacobaltss
Nov 7, 2015 02:25 PM
dennis69
Oct 20, 2015 04:49 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
