need some help n suggestions
Old Jun 27, 2011 | 11:15 AM
chrism0589's Avatar
so i installed my pedder springs like 2-3 weeks ago. i like the drop but the ride quality of my car sucks now. i have a lot of noise that comes from the back when ever i have people in the back and i hit ANY bump. big bumps sound really bad. and now in the front passenger side i have a weird clunking noise that only happens when i start moving. i don't know what it could be.
my main question is what i can do so the ride isn't too rough? like soften the impacts from bumps and holes?
any help is appreciated
Old Jun 27, 2011 | 11:17 AM
BlueTurbo's Avatar
Make sure you aren't hitting the bump stops, they need to be modified with lowering.
Old Jun 27, 2011 | 11:21 AM
07BoostedG5's Avatar
I get that clunking too, did you pay attention when putting the struts back together to seat the top of the spring in the same loaction as stock? my pass side is not right, and I think thats my clunking sound, happens on speed bumps
wtf is with the clunk! yours is pass too! ** I just read it again lol
see i had this sound before pedders, and I knew I lost the correct placement of the strut mount, but know Im trying to fix it, When I jack the car up and can twist the spring so that why I think its the mount not seated correctly
Old Jun 27, 2011 | 11:54 AM
chrism0589's Avatar
what type of modifications do i have to do?? and it isn't just a hitting sound. i also like a squeak. i don't know how to explain it. its just weird.
Old Jun 27, 2011 | 11:56 AM
chrism0589's Avatar
when i installed them with my friend we made sure to line up the strut/shock back to how it was. so idk what it could be.
also my main concern is making the ride less rough. do u guys think aftermarket shocks would help??
Last edited by chrism0589; Jun 27, 2011 at 11:56 AM. Reason: Automerged Doublepost
Old Jun 27, 2011 | 11:59 AM
The rough ride is the nature of the beast when lowering.
Did you cut your rear bump stops? there a foam insert in the top spring seats, they did to be trimmed.
Old Jun 27, 2011 | 01:33 PM
chrism0589's Avatar
i knew it was gonna be a rougher ride but is there something i can do to make it less rough? lol
and no i didnt cut anything. how much do i need to cut?? and do i only have to cut the top one??
Old Jun 27, 2011 | 02:04 PM
theres only top ones so yes, cut about a inch to 1.5 off. and no theres nothing that you can do, and pedders is not bad man, try riding on sportlines its like square tires! I have been on just about every spring pedders is the closetest yo stock feel, fix your bumpstops 1st, it will help.
Old Jun 27, 2011 | 02:18 PM
chrism0589's Avatar
so u dont think shocks would help with the ride quality?? also having 18's makes it worse right?
Old Jun 27, 2011 | 02:27 PM
depends if you have alot miles on the shock/strut then yes or if you have had a major drop spring on them for awhile it will kill them too, Thats what happend to me with sportlines and I went over to fe5's. but if this is your 1st lowered car and going from base suspension then really its just a matter of getting use to it.
Old Jun 28, 2011 | 02:19 PM
BlueTurbo's Avatar
If it is a squeak/rub type noise, check and make sure the spring is seated properly on the insulator.
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
TedSS
26
Oct 10, 2015 04:30 PM
yellow dragon
Sep 28, 2015 09:49 PM
budah93
Sep 23, 2015 02:26 PM
