New control arm bushings
Old Dec 10, 2013 | 11:55 AM
inflamesnation's Avatar
Just putting these out there in case nobody has seen these
Federal-Mogul eCatalog Resource Center
Old Dec 10, 2013 | 12:11 PM
Staged07SS's Avatar
Administrator
Administrator
Have them installed in my CAB's since May.
They work great
Old Dec 10, 2013 | 12:13 PM
yellowsupercharged06's Avatar
i just picked up a set from OTTP (their new design) ... i will be doing a full review on them as soon as they arrive.
How is the install on these ?
Old Dec 10, 2013 | 12:15 PM
Staged07SS's Avatar
Administrator
Administrator
Not bad. Put them in the freezer for an hour or so before installing them.
This will help make them contract, and make them easier to press in.
Also grease them up.
Old Dec 10, 2013 | 12:18 PM
ok thanks for the tips..
do i need a press at all or is it do able with regular tools ??
574's Avatar
574
Subd, not sure if I need new ones or not
Old Dec 10, 2013 | 12:42 PM
Staged07SS's Avatar
Administrator
Administrator
I used a ball joint press kit.
Old Dec 10, 2013 | 11:20 PM
andrewcarr1993's Avatar
Have powells, he put them in himself even. Great guy and you can't go wrong with his parts.
Old Dec 26, 2013 | 04:39 PM
Econobox's Avatar
I had a bad time replacing my CAB with a ball joint press. I needed a sawzall for the metal ring (eventually the center of the bushing separated from the ring). I used a vice to press the new one in, which frankly I wouldn't recommend but it works (you have to keep rotating the arm to press each side a little at a time).
However the second time around I used a press at a local shop. It was much easier for both removing and installing, especially installing.
It took MUCH longer to remove and install the bushing with a ball joint press and vice than removing the control arm itself, whereas it took much longer to remove and install the control arm than the bushings when I used a press.
The distinct memory of using a 5 foot cheater bar on the ball joint press and pulling with all my might, sweating my ass off, will prevent me from ever doing that again.
Old Dec 26, 2013 | 04:42 PM
noorj's Avatar
use a press, if you can't find one many tire/lube shops will do it for you for $20-40 if you bring them the bare control arms with the new bushings you want in
Old Dec 26, 2013 | 05:03 PM
YelCal7's Avatar
I know a local guy does press for $10. I can't wait for my OTTP CAB come in 2 weeks. I've been waiting since Dec 16 that they advertise will be shipped out but not. They are waiting for that guy machine them and I know they are busy cause of holiday.
Old Dec 27, 2013 | 07:19 AM
Staged07SS's Avatar
Administrator
Administrator
I had no issues with the ball joint press I used.
In 15 mins, I had the old ones pressed out and the new ones pressed in.
Old Dec 27, 2013 | 09:32 AM
Econobox's Avatar
That's pretty much what I was expecting. It just wasn't the case for me. I'm talking at least an hour of torquing on it with a 5 foot bar, and in the end it just disintegrated before actually popping out. It got me thinking about getting a cheap press since there isn't much to them really.
DANRICKARD
Oct 1, 2015 12:08 AM
footballplaya3k
Sep 30, 2015 09:39 PM
yellow dragon
Sep 28, 2015 09:49 PM
Coballin13
Sep 25, 2015 08:43 AM
