New GM TSB; Availibility of steering knuckles for competetive driving.
Old Oct 6, 2006 | 12:54 PM
Nukem's Avatar
I think it would be well worth the money for those of us that do a lot of AutoX and Road Racing.
Old Oct 6, 2006 | 01:03 PM
LittleStealthSS's Avatar
I agree that it would be. THe issue that some will have to consider is classification .. At least in Solo. If this would be a "recall" or if GM called it a "replacement part" and not had the Competition replacement ( or however it's worded ) in there, then it might not be an issue.
To the SCCA, this MIGHT be a competitive upgrade that is above an OEM part, and then that would constitute that it's NOT eligable for use in a stock classed car.
Road racing is a whole different ballgame.
Old Oct 6, 2006 | 04:01 PM
Nukem's Avatar
yeah. U have a point it seems everything these days are based on wording.
Old Oct 12, 2006 | 01:26 AM
redblur's Avatar
Seeing that it's a replacement for a part that came from the factory, and I'm sure there's no weight savings or other performance benefits, then how could they list that as a class-changing part?
Old Mar 22, 2007 | 03:11 PM
biohazard's Avatar
Get low
should i loook at installing these to go with my air-ride?
Old Aug 26, 2007 | 03:56 PM
OneAMCoffee's Avatar
I can't see quite why you would need it for an air suspension, you are going vertically, not laterally.
Regards,
Ryan
Old Nov 10, 2008 | 05:53 PM
BigBrother's Avatar
The SCCA issued a FastTrack line specifically dealing with this part for those who didn't see it a couple months ago; straight from teh SEB, this part is NOT eligable for stock class in Solo. IIRC, they can't be used in ST either. DSP, SM, or SMFshouldn't be an issue.
I have autocrossed the unholy hell outta my IRL now and haven't broken a knuckle, but when I change class you can bet your ass they're going in, lol.
Old Dec 12, 2010 | 04:54 PM
mongorat427's Avatar
Pontiac G6 are the ones that are heavy duty compared to the LNF spindles
Old Aug 20, 2011 | 08:05 AM
Atreus's Avatar
I do not autocross but I will go to track days maybe 3-4 times a year. Is the replacement recommended only for autocross or is it also recommended for track use?
Old Jun 21, 2012 | 11:24 AM
insylem's Avatar
Originally Posted by Halfcent
Pretty quick, maybe 30 minutes per side. And you shouldn't need an alignment afterward unless you wanted those racing specs listed in the TSB. If you have a decent jack you can do it yourself.
I had them installed and it braught my toe way in so it DOES need an alignment after the install
Solaris99
28
Mar 15, 2017 01:22 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
TedSS
26
Oct 10, 2015 04:30 PM
importkiller
Sep 30, 2015 07:18 PM
