A new noise, speed dependent howl
Old Jan 16, 2014 | 08:57 PM
nickflanders's Avatar
So out of the blue I have a new noise, at about 15 mph and up to freeway speeds I have a howl that gets progressively worse. I jacked up the car and noticed a wheel bearing had some play up front so immediately I replaced it. At the same time I checked out 4 corners.
Basically I still have the noise and the problem was not the wheel bearing. I have since tried to turn and see if the noise got worse or quieter and it is the exact same, no difference in turns, on throttle or brakes.. I am officially stumped here. My next guess would be trans related which I pray it isn't... Am I missing another cobalt related front end flaw?
I have an 06 ss/sc G85 with 120k
Old Jan 16, 2014 | 09:13 PM
andrewcarr1993's Avatar
Everything seems to point at wheel bearings is it possible another one is bad too? If you're sure it's not that though I'm stumped, sorry.
Old Jan 16, 2014 | 09:48 PM
UltraSilverSS's Avatar
Maybe your clutch is about to take a ****
Old Jan 17, 2014 | 09:53 AM
My next step is to swap wheel bearings again and see if it makes a difference. I'm wondering if the LSD is keeping a load on both wheels when turning and that's why my noise is constant while turning..
biniecki
Oct 25, 2015 02:23 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
jimbofug007
Oct 2, 2015 12:06 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Extremespeed
Sep 29, 2015 04:34 AM
