parts list for front end rebuild?
Old Jan 3, 2020 | 05:41 PM
Johnny Bliss's Avatar
Anyone know off the top of their head what parts i should buy to rebuild my front end suspension including steering?
i already have new sway bar end links and sway bar bushings...
Old Jan 3, 2020 | 05:50 PM
tie rod ends, inner and outer
steering shaft
struts/upper strut mount
sway bar link and bushing
control arm bushings, leading and trailing
ball joints
Old Jan 3, 2020 | 05:52 PM
thx, i forgot i have a new steering shaft but when i tested mine it was still OK. but i might put it in when i do everything else just to save myself from having to redo it.
im kinda on the fence about keeping my car or moving on to something else. i really like the car and its a very reliable beater/daily. but i'm itching for a v8
Old Jan 3, 2020 | 05:53 PM
does it make sense to just replace the bushings in the control arms or just buy new complete ones? afaik the car has never been in any front end accident but about a month or so ago is randomly started pulling to the left
Old Jan 3, 2020 | 05:59 PM
tomss's Avatar
Struts and associated hardware (https://www.gmpartsdirect.com/auto-p...uspension-scat)
Control arms (https://www.gmpartsdirect.com/auto-p...omponents-scat)
Possibly rebuild axles and hubs
Steering rack and tie rods (https://www.gmpartsdirect.com/auto-p...d-linkage-scat)
For the web links, I just used my car as an example - 2009 SS
Old Jan 4, 2020 | 01:01 PM
these cars arent even worth sellIng imo. Just buy what you want and keep the car instead of taking 1500 on a trade in.
Old Jan 4, 2020 | 01:14 PM
It's a shame isn't it
Old Jan 4, 2020 | 03:43 PM
hrspwrjunkie's Avatar
Don't forget to do a careful check of the hubs. Mine were toast at 55,000 miles and played havoc with front end diagnosis.
Old Jan 4, 2020 | 05:16 PM
I wish there was something I could do about the 60s and random misfire that doesn't include hundreds of dollars for hptuners or a custom tune
I sprayed the entire engine with starting fluid and found no leaks. I put a new evap solenoid on and nothing changed
Almost every sensor is new
Old Jan 4, 2020 | 07:49 PM
Tested fuel pressure and it was solid 60
Old Jan 5, 2020 | 11:44 AM
bahoodle's Avatar
probably wont help but i did a crank relearn on my buddies 07 ss/sc and it got rid of the misfires it was having
Old Jan 5, 2020 | 02:30 PM
I heard about that working from your other post. I might try it but i would have to pay the dealership I don't know anyone with the right tools
Old Jan 5, 2020 | 09:48 PM
bahoodle's Avatar
id take it to a independent shop, do you have a p0300 or does the car just sometimes buck? i had a loose crankshaft position sensor wire and the car was kinda strange til i found that issue, it was a 07 too but idk do u just have a p0300? id do a injector balance test on it maybe you have 2 injectors that are dirty or sticking open or closed from time to time and not setting a p0301-304 cuz its not doing it consistently enough
Old Jan 6, 2020 | 10:56 AM
its p0300.
the 60lbs i have are brand new its done it since i put them and the tune in, didnt' do it with Gm STG2 42s and tune
Jesse1991
May 14, 2015 11:39 AM
talkeddelta8
Nov 14, 2014 12:37 AM
Sachemhockey44
Oct 27, 2012 01:17 AM
buildmeanempire
Oct 8, 2012 12:15 PM
Pandru
Oct 25, 2010 12:21 AM
