Pedders & Rack Spacers
Old Feb 12, 2011 | 02:31 PM
AcesNEights's Avatar
Long story short...put pedders on last summer, had bump steer. Got new tires put on in January, bump steer gone. Put rack spacers in this morning, bump steer back.
Should I just say *uck it and take em out or what the hell? Kinda pisses me off I did all that work grinding down the trans mount and it just made it worse...Wasnt acually that much work but still.
Old Feb 12, 2011 | 02:46 PM
rallyracer's Avatar
after rack spacers pretty sure you need an alignment.
Old Feb 12, 2011 | 02:50 PM
Dart_SI's Avatar
u gotta grind down the tranny mount to install rack spacers?
Old Feb 12, 2011 | 02:53 PM
pbass's Avatar
No grinding involved on mine. Ask John what applies to your specific model, he invented the spacers.
Yes to alignment after putting on the spacers. That's why I put the springs and spacers on at the same time.
Old Feb 12, 2011 | 03:12 PM
importkiller's Avatar
I have no bump steer with my spacers and pedders and no grinding was required. are you CABS still good? Are there other parts that went out? First get an alignment.
Old Feb 12, 2011 | 03:23 PM
ssyellowss's Avatar
There shouldn't be any grinding to install rack spacers....
I'd look over everything to make sure it all looks ok. Maybe your steering rack came loose, or CABS could be worn. I wouldn't blame the spacers first since they're designed to fix the problem, especially with aftermarket springs.
Old Feb 12, 2011 | 05:20 PM
I couldnt slip the driver side spacer in, it hit the rear trans mount. I only had to take like a 1/8th inch off, nothing major.
Im hoping everything just needs snugged up. Our roads arent the best up here durin winte so they dont help. But i dont drive the car in winter so im not to worried bout it as of now.
Old Feb 12, 2011 | 05:45 PM
Wangspeed's Avatar
You need rotated mounts to put in the appropriate size spacer. The 5mm spacer isn't thick enough, as I've found out. 8mm is what you want if you're on Pedders.
Old Feb 12, 2011 | 06:01 PM
I got em from TTR, there 1/2 inch.
Old Feb 13, 2011 | 02:17 PM
Took the car out agin today. Doesnt make the noise, only on my street, which is terrible btw. So Im assuming everything is good, gonna recheck the torque on them next weekend.
Now if I could just figure out the rattle in the back
Solaris99
28
Mar 15, 2017 01:22 PM
Tupp
Sep 30, 2015 08:18 PM
goaliemo
Sep 28, 2015 01:37 PM
