possible intermediate shaft solution
Old Apr 20, 2010 | 04:20 PM
bigmd's Avatar
im not sure if this is the right place to post but i found a possible fix for the annoying steering clunk.
http://www.latemodelrestoration.com/...Steering-Shaft
it may fit as it says it is able to be shortened.what do you guys think.i for one am fed up with that noise.
here is the tech article
http://www.mylrs.com/blogs/lrs/archi...let-tahoe.aspx
Old Apr 20, 2010 | 08:53 PM
krawzdogg's Avatar
If someone could prove this would solve the problem I wouldn't hesitate ordering one.
Old Apr 20, 2010 | 08:55 PM
Mr_Slobalt's Avatar
won't fit
Old Apr 20, 2010 | 10:42 PM
bigmd's Avatar
why not?
Old Apr 22, 2010 | 11:06 PM
Mr_Slobalt's Avatar
too big, too long, the ends of the shafts are completely different from ours....
I've replaced/removed/lubed a lot of the upper i-shafts on Tahoes, Silverados, Yukons, Suburbans, etc. and I've replaced/removed/lubed several Cobalt i-shafts.
I was hoping GM would eventually release updated intermediate shafts for our cars like they did the Malibus (previous), but I guess we're not that lucky. Malibu i-shafts are even more garbage than ours though.
Your best bet is to lube the shaft with lithium grease and "stroke it" to work the grease in or replace the whole shaft. Sometimes loosening the bolt where it attaches to the steering gear and lifting up on the shaft (with a pry bar) while tightening this bolt helps a bit.
Old Apr 23, 2010 | 08:24 AM
bigmd's Avatar
damn,that sucks.i thought this might work.what about Flaming River?they make alot a steering components for mustangs.camaros,etc.......
hacadacalopolis
Oct 28, 2015 06:09 PM
metroplex
Sep 27, 2015 07:48 AM
Cptnslo
Sep 24, 2015 09:32 AM
