Post your pad/rotor setup!
Old Aug 4, 2014 | 10:29 PM
chris88z24's Avatar
Right now I'm running OEM AC Delco ceramic pads and Durastop rotors. The pads are great with no dusting, but the rotors are garbage. I torque my lug nuts to 100 ft. lbs every time and these rotors still warped after a few thousand miles.
Old Aug 4, 2014 | 11:14 PM
DFZ24's Avatar
HPS pads front and rear.
Front R1, EBC rotors warped.
Rear OEM rotors.
Old Aug 5, 2014 | 11:02 AM
BlackielawlessSS's Avatar
Stock ford on all 4 wheels
Old Aug 5, 2014 | 12:45 PM
LNFTX's Avatar
Durastop rotors.
Here's your problem they are crap stock is better napa gold if you hate oem
Old Aug 5, 2014 | 01:00 PM
Staged07SS's Avatar
Administrator
Administrator
Powerslot rotors
Hawk ceramic pads
Been running this setup for 4 years now.
When I need new pads, I'm going to go with Hawk HPS.
Old Aug 5, 2014 | 01:06 PM
Spawne32's Avatar
Centric High Carbon Alloy Rotors $55.79x2 FRONT
StopTech Street Performance Brake Pads $39.79x1 FRONT
I laugh at these 500+ dollar brake job's on daily drivers. I've never used a torque wrench on lugnuts in my entire life. Air compressor + matco impact gun and go.
Old Aug 5, 2014 | 01:08 PM
chris88z24's Avatar
They're the DuraStop Professional series, one step above OEM.
Old Aug 5, 2014 | 01:24 PM
06 pursuit gt's Avatar
R1 premier and hawk hps all around. Little dust no noise and look good.
Old Aug 5, 2014 | 01:29 PM
Fidget's Avatar
Ditto though Im running the OEM Brembo pads on my setup since they were new when I got the calipers but will be changing to Hawk HPS on the front when it comes time.
Old Aug 5, 2014 | 03:37 PM
colodude18's Avatar
Stock rotors, stock Brembo/Ferrodo pads (street)
Stock rotors (2nd set), Hawk DTC-70 race pads (road track)
Stock brakes on an LNF are so underrated! They perform extremely well even in serious mountain driving with ZFR power. Hawk DTC's are in a class of their own but expensive ($260 for just front pads), and of course very dusty and very squeaky but that's a given with race pads.
Old Aug 5, 2014 | 04:30 PM
speedbugy996's Avatar
When stock I ran centric high carbon rotors and stoptech street/trackday pads, tried ebc and they sucked! Now I'm running a brembo conversion on my RL so, brembo rotors/pads up front and centric/stoptech on rear. Hawk's I've tried on both set ups and while they worked well, they seemed to eat rotors faster. I also tried carbotech's 10s up front and 8s in back and that worked well but was pricey, probably balance out price wise when compared to the hawk's pads due to them chewing up rotors.
Old Aug 5, 2014 | 04:35 PM
footballplaya3k's Avatar
R1 premium slotted and Hawk HPS all the way around. I love the setup. If you don't autocross your car there isn't a better setup.
I've had the Hawks for about 15k miles and barely have any pad or rotor wear.
Old Aug 5, 2014 | 04:54 PM
I run a lot of track miles which is what kills my brake rotors/pads so quickly. I will go thru 2 or 3 sets of pads per race season and fresh rotors every spring. With the hawk pads/stock rotors I was changing rotors and pads almost 1 to 1 ratio. And at some tighter tracks the hawk's would heat crack once they got down to 50%, cooling ducts would probably help that some, but easier and cheaper just to run a better set up on the brakes. If you are running them in autox hawks should be fine as the heat never builds up as high as on track. Unless you are competing or track days centric high carbon and centric pads be fine for street use.
Old Aug 5, 2014 | 06:37 PM
colodude18's Avatar
Not sure if you're talking about the Hawk DTC pads, but they are designed to eat up rotors. At $260 a set (front) that makes sense since a set of OEM front LNF rotors can be had for under 70 bucks shipped, making it much cheaper to replace rotors than pads
Old Aug 5, 2014 | 07:51 PM
hawk hp plus, never ran the dtc blue ones, tried carbotec's next like them but pricey..then I got a good deal on the brembo kit and went that way instead of messing around futher. might consider going to powell's coleman rotor set up in the future.
Old Aug 5, 2014 | 08:06 PM
LNFTX's Avatar
Says the manufacturer
From my personal experience they are made of inferior steel had them warped three sets
Now I use stock pads stock rotors with no warping issues
Old Aug 5, 2014 | 08:58 PM
I agree, napa gold is what I ran on my SS
Old Aug 5, 2014 | 09:29 PM
Omiotek's Avatar
Coleman floating rotors up front and r1 slotted in the rear. feroddo hp1000s up front and stock rears
Old Aug 5, 2014 | 09:45 PM
If anyone is looking to reduce brake dust the Hawk HPS are the way to go.
Old Aug 5, 2014 | 10:22 PM
chris88z24's Avatar
What are the stock rotors? These? More Information for ACDELCO 1771004
Old Aug 5, 2014 | 11:49 PM
LNFTX's Avatar
Dont think so but I drive an lnf
This thread shows different numbers
https://www.cobaltss.net/forums/show...518&styleid=10
Amazon has a good price with free shipping
http://www.amazon.com/gp/aw/d/B0031I...&robot_redir=1
Old Aug 6, 2014 | 12:07 AM
Whitnith's Avatar
LSJ with Brembo swap on front:
Front:
Street: Stock LNF rotors and Brembo pads
Track: Centric rotors and Raybestos ST-43 pads
Rear:
Centric rotors and HP+ pads
Old Aug 6, 2014 | 12:49 AM
bnutz's Avatar
What's the R1 premiums and where can you get them at
Old Aug 6, 2014 | 01:09 AM
meatsac69's Avatar
Stock i need to upgrade i know, i need to get slotted and drilled rotors mine are almost bad anyone know a good priced set?
Old Aug 6, 2014 | 09:36 AM
chris88z24's Avatar
Dont think so but I drive an lnf This thread shows different numbers https://www.cobaltss.net/forums/show...518&styleid=10 Amazon has a good price with free shipping http://www.amazon.com/gp/aw/d/B0031I...&robot_redir=1
Those are the cheap rotors.
