Question for those running Ksport Coilovers
I just got mine in the mail...not installing for a few weeks but I'm trying to get all my bearings under me before I start. I did my CM springs with the help of my uncle so I'm good with the actual install part but I'm trying to figure out exactly how much adjustment I need to do on the front. I see that the height adjustment is done with the lower mount but how far should that mount be from the bottom of the locking nut holding the spring in place? I know it all depends on how low you want to go but surely these things have a max or safe zone. Also I've attached a picture of a few parts I'm unsure about. I don't really see a use for them but I'm hoping someone that has installed these can chime in. If you have a picture of the front strut on the car that would be helpful.
Are you talking about the damping adjustment or the locking rings? I am assuming you are talking about the damping because that is the only thing on them that would "click." It depends, too stiff and every bump you hit will feel like a 2 foot deep pothole, too soft and you will be bouncing up and down like a low rider. Also if you are low and you have the strut damping too soft you will rub everytime you hit a bump or bottom out.
Iceberg
Sep 29, 2015 12:33 PM
