quick question before fe1 to fe5 install
Old Jan 9, 2013 | 12:47 PM
yeti as3's Avatar
I have an 06 LS. I am on my way to pick up ss/tc fe5 struts/shocks and pedders. Do I have to get the shorter ss/tc end links (would get Moog) for the sway bar? I will be using the stock LS bar. I though I read that I would need them but dealer says they are not needed. Thanks! I'll get pics up tonight
Old Jan 9, 2013 | 01:13 PM
BronxKnight28's Avatar
you dont have to, i still have my stock ones on that i havent had time to change to the moog endlinks i bought. its suggested though
Old Jan 9, 2013 | 04:21 PM
yeti as3's Avatar
I ended up buying the correct links anyway. Found out I had one that woith a torn seal. Starting the swap now.
Old Jan 9, 2013 | 04:37 PM
nhanson's Avatar
Good thing you didnt buy shorter ones. Shorter ones will screw up your sway bar bushing and cause it to make noise.
Use shorter ones if you upgrade your sway bar to FE5
Old Jan 10, 2013 | 01:18 AM
yeti as3's Avatar
I did and I have a lot of noise. Guess I will pick up the fe1s in the morning. I also think I didn't line the tab up correctly on the top hat which may contribute to the clunk. Looks like I have some fixing to do.
Old Jan 10, 2013 | 05:45 PM
IonNinja's Avatar
What if you're lowered a considerable amount? FE1 endlinks seem to be too long for me
Old Jan 11, 2013 | 05:40 PM
nhanson's Avatar
I have CM springs and used shorter links and have noise.
Old Jan 11, 2013 | 06:36 PM
yeti as3's Avatar
I felt the fe1 links had the sway bar dropping below the control arm with the fe5 struts. I did end up running the sc/tc links and mine is quiet thus far and the bar position seems correct. I have about 100 miles on the setup. I used the Moog Part No. DW-K750012 (250mm)
Old Jan 11, 2013 | 06:52 PM
BlackARCA06's Avatar
I ran with the FE1 links on eibach sportlines and FE5 suspension with no noise or anything on my old cobalt. Eventually I went with the Fe5 moogs though.
Old Jan 12, 2013 | 08:13 AM
Could be CABs or just that the end links arent tight enough. I've driven like 20,000miles on a combo of SSi springs (damn low for springs) with Koni Yellows, then switched springs to Powell's YYZs with the FE5 endlink and have no front end noise. A friend of mine on his SS/TC (stock FE5 shocks and endlinks, and I think HHRs) had clinking over bumps, so we tore into his front end and low and behold the endlinks had loosed up (or he didnt tighten them down correctly) re torqued the bolts the noise disappeared.
Old Jan 12, 2013 | 06:39 PM
IonNinja's Avatar
Cool, good deal...will pick up some FE5 endlinks eventually then
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 07:39 AM
patooyee
Oct 15, 2015 05:11 PM
justinchinn
Oct 2, 2015 12:18 PM
Coballin13
Sep 25, 2015 08:43 AM
