quick question regarding installing axle
Old Oct 1, 2014 | 06:29 PM
happygil0303's Avatar
Im replacing my passenger side axle. When fitting it in the intermediate shaft you have the splines in the bracket and then the splines in the actual shaft. It seems as though the c clip on the axle is going in as far between both set of splines, leaving only maybe a half inch of splines on the axle to connect with the intermidiate shaft splines. Is this normal or should it fit farther in?
Old Oct 1, 2014 | 06:43 PM
Mr.Tozzi's Avatar
it should fit as far as it takes to lock it in place.
Old Oct 1, 2014 | 07:20 PM
double clutch's Avatar
If i were you i would replace both. I snapped my driver side and replaced both just so i didnt have to worry about the other one
deviance
Nov 24, 2015 05:51 PM
biniecki
Oct 25, 2015 02:23 PM
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 07:39 AM
justinchinn
Oct 2, 2015 12:18 PM
