Rear axle bushings
Rear axle bushings
Has anyone changed these out, and if so is there a how-to? I checked but could not find it. Only thread I've found is this - https://www.cobaltss.net/forums/susp...shings-301971/ - however I have no idea what the "kent moore" tool is or what specifically I need it for. I'm looking to replace mine, but I have no idea how to go about it.
I'm not sure if there's a how-to per se, but there are a couple people that have changed out their rear axle beam bushings...
The Kent Moore tool is needed to change out the bushing. You have a couple options, I'm not sure if companies like Moog make them... so you can get OEM bushings or some Powell rear beam axle bushings. The latter option is a bit pricier, but Powell will include the Kent Moore tool to swap out the bushings, you would just need to return the tool once you are done.
Halfcent also replaced his bushings, you can check out his thread below:
https://www.cobaltss.net/forums/susp...ushing-283354/
07Blac, can you point me in the right direction for the tool? There are apparently a million and one tools associated with the Kent Moore name. I have no idea which one I need.
Thanks
Lets put it this way, there's a replacement that'll offer a benefit to handling and although more expensive will never fail. Then that's what's going on my car nothing worse, do it right once and be done with it.
he is looking for the tool and a cheap stock replacement part.
Thank you. And it's not like Moog parts are crap. They are better than stock and almost always cheaper.
Intel's part number was right, but the cheapest on E-bay at the moment is 110 shipped.
I'm not in a hurry though so I'll keep my eyes open for a deal. Or maybe I can find a way to borrow one. It's unlikely that I'll ever need to use it again.
Does Advance or any local auto parts store have that tool for rental by any chance? You might want to also see if a tech at a local dealership will press in those bushings for you for like $20-$30.
Good call, Autozone rents out all kinds of various crap. I'll do some digging.
folks who buy our bushings get a tool shipped to them and then they send it on to the next guy. It cost more than 110 shipped. for sure. might even buy another tool mine will get worn out at 110 shipped.
parts for my kent more tool for front CABS JUST THE REPLACEMENT BOLT is $275.00 . YIKES!!
lol remove rear beam get truck. load it up, take it to dealer find they dont have the tool etc.
DANRICKARD
Oct 1, 2015 12:08 AM
Delta coupe
Sep 30, 2015 08:11 AM
