Rear Brake piston tool
Ok..I just found out the tool I have and what most kits have is too big to fit our small pistons. The spacing between the pegs is to great.
I found the right adaptor to fit here:
Schley Products, Inc , 67380 3/8 In Dr Brake Caliper Tool Adapter - Mazda Mini Volvo
•This new 3/8” brake caliper adapter has been specially designed to work with other brake caliper tools available on the market.
•This new adapter can be used for Mazda, BMW, Mini Cooper & Volvo vehicles.
•These vehicles have smaller brake pistons than other vehicles.
•In operation, the tool makes clearance for new, thicker brake pads by rotating the brake piston back into the caliper until the piston is bottomed.
•Rotating the piston is required on most disc brake calipers which are also used as emergency brakes
I'd rather spend another $25 and get the one that braces against the opposite side of the caliper. You'll see. Sometimes the piston twists right in. Sometimes you need to eat your wheaties, or use a better tool
I'm talking about the autozone rental kit, none of the adapters quite fit our pistons. I haven't used the tool you posted, was just trying to reiterate what you said in the op
Needle nose pliers here!
On a different subject..LUBING PINS?
Here is the same caliper above showing the pin area. NO LUBE and exposed pin (no inner boot ). Do ya think they have our rear rotor/pad problems? NO! It must be the FU$$KN PADS we have!
PIC of Volvo rear caliper and PINS:
I'll take this one 18 Piece Disc Brake Pad and Caliper Service Tool Kit but only because it comes with 17 more pieces and I'm more than likely going to use at least 1 of them.
You've obviously never done very many of these. Once in a while you run into pistons that will not rotate and compress without a very large amount of force. I've had this happen on Audis, VW, GM, etc. It sucks. Using needle nose pliers is stupid. You risk tearing the boot when you run into a piston that does not want to compress.
lol but i get wat u mean about the boot and them bein harder than other to compress or rotate
Exactly what I said. When it doesn't want to compress, if you're using pliers, they are likely to slip, and you'll probably stab the boot.
Even using the cube thing is no good. What you want is the Harbor Freight kit. The last time I did mine, one of the pistons did not want to compress. Fortunately, I had access to a kit like the HF tool, and got it to compress with that.
This is why I suggest a real tool which allows you to compress and rotate very easily. Not the crumby cube thing, or pliers (come on).
