rear suspension problem
Old Apr 10, 2015 | 04:42 PM
blackphoenix's Avatar
So i bought the lnf strut and yyz package from ced. After the install it seems the rear height didn't go down all that much and seems really bouncy and squeky. If I push down on the rear end the car moves up and down quite a bit. Here are some pics. Any ideas?
Attached Thumbnails forumrunner_20150410_164126.png   forumrunner_20150410_164134.png   forumrunner_20150410_164144.png   forumrunner_20150410_164154.png   forumrunner_20150410_164202.png
Old Apr 10, 2015 | 04:54 PM
umrdyldo's Avatar
Excuse my language, but holy rust!
Guess I see why the northern guys have issues.
As for the car. That doesn't look right as far as ride height. Did you install the shocks the correct way? Does the drivers side look the same?
What springs do you have up front?
Old Apr 10, 2015 | 05:01 PM
yeah same height on both side. the fronts have yyz springs as well. the shocks are installed right as far as i know.
Old Apr 10, 2015 | 06:13 PM
Grave's Avatar
The shocks wouldn't affect the ride height.
It's possible the springs aren't installed completely on the isolators. They are a tight fit sometimes. I can't tell in the pictures.
Old Apr 10, 2015 | 11:52 PM
dmstk8d1's Avatar
Not sure if it is the case, but most of the time the tight coils on a progressive springs sit at the top. Your pic shows them at the bottom. I would do some research, maybe email Powell, and see if they should be flipped over.
Old Apr 11, 2015 | 08:28 AM
Im going to email powell and send them the pics, it is strange. Thanks guys
Old Apr 12, 2015 | 02:29 AM
dmstk8d1's Avatar
Let us know what you find out. I did a quick google image search and it showed the tight coils facing up towards the trunk pan. As easy as it is to change the rear springs, you may just wanna flip them over and see if that cures your issue.
Old Apr 12, 2015 | 08:30 AM
To what ive heard on yyz it doesnt matter what way they face on the rears according to powell. I have them installed the same way as him and have no problems
Old Apr 12, 2015 | 10:48 AM
I talked with powell, he told me to flip the springs and see if that fixes it.
Old Apr 12, 2015 | 10:50 AM
Hmm lets see what happens
Old Apr 12, 2015 | 01:01 PM
No change. Exactly the same.. very strange.
Old Apr 16, 2015 | 04:46 AM
dmstk8d1's Avatar
That sucks man, don't even have any further ideas to throw your way. I assume the CED kit was new front struts and rear shocks?
Old Apr 16, 2015 | 08:00 AM
Cherry GT's Avatar
That's what I was told.
Old Apr 16, 2015 | 08:41 AM
umrdyldo's Avatar
what happens when you throw stock springs back on?
Old Apr 20, 2015 | 09:19 AM
yeah i bought the whole kit from CED springs and strut package. i haven't had time to do anything else with it. my next change will be putting the original rear spring mounts back in and see how it sits. i bought all new mounts when i bought the package. hopefully i'll be able to swap them out this weekend.
Old Apr 20, 2015 | 10:18 AM
What size tire are you running?
Old Apr 21, 2015 | 11:59 AM
stock rims and tires
Old Apr 21, 2015 | 12:03 PM
so 215/45/18, 205/40/17, or 225/40/18?
Last edited by Staged07SS; Apr 28, 2015 at 02:57 PM. Reason: SS/SC stock tires are 215 45 18
Old Apr 28, 2015 | 02:37 PM
so i'm giving up and going back to stock, no one can figure it out. i've talked to a few local shops and everyone is stumped
Old Apr 28, 2015 | 03:10 PM
96S1's Avatar
Did you do the install yourself? If so, take measurements from the ground to the lip of the rear fender on both sides, and then again once you put the stock components back on.
If you did the job yourself, and you plan on going back to stock, post a step-by-step process and take pictures, even if you're just putting the stock stuff back on. This might help us diagnose the issue over the internet.
Also, your first description seems a little vague. You said that when you push down on the rear end the car moves up and down quite a bit. Are you talking after you remove your hands, it still bounces up and down on it's own? Can you post a vid?
Old Apr 28, 2015 | 04:43 PM
no , i had it installed with a friend who does this for a living. he's installed these springs before with no issues.
it bounces like it has bad struts( which of course are brand new) it doesn't take much effort at all to get car to bounce, i can do it with one hand. the fronts are solid and stiff and won't budge when pushed on. it's taking up to much of my time and the car drives like crap. i'd rather just go back to stock and not deal with the headache.
Old Apr 28, 2015 | 04:46 PM
So are you shipping the springs and shocks back to CED or Powell to figure out whats going on?
Old Apr 28, 2015 | 07:38 PM
they don't want them, they tell me there's nothing wrong with them. I'm just going to sell them cheap. it'll probably work fine on another car
Old Apr 28, 2015 | 11:36 PM
andrewcarr1993's Avatar
How cheap is cheap?
Old Apr 29, 2015 | 07:28 AM
Staged07SS's Avatar
Administrator
Administrator
Some Tein coil insulators would have helped with the noise.
This is the first time I heard of an issue like this with Powell springs though.
