Rear twisting beam
Old Aug 20, 2012 | 04:21 PM
BlackLsCoupe's Avatar
Rear twisting beam
i got a clunk noise from the rear when going slow over entry ways. i think my beam is hitting the exhaust but then since i seen rear twisting beam bushings. do these go bad? my last cobalt never made this noise
Old Aug 20, 2012 | 06:48 PM
emiller's Avatar
Any bushing will eventually go bad. Shouldn't be that soon though.
Have you done any work that involved the rear suspension?
Old Aug 20, 2012 | 07:22 PM
lowerd it. but it was makeing noise before. also had to move the rear end during an alignment and time of spring install. i think it got hit hard on drivers side, and car fax didnt tell me
Old Aug 20, 2012 | 07:24 PM
blazerlow's Avatar
I just got done doing a small notch in my rear axle to clear the exhaust. I am lowered on B&G springs and have the GMPP exhaust so it was hitting and rattling. Just a very small notch is all that is needed to make it clear. I welded it all up and made it nice and smooth and painted it black again. looks factory.
Old Aug 20, 2012 | 10:33 PM
BLKLS's Avatar
Stock exhaust? Mine hits on the body as it goes over the axle. No way for me to fix it with out cutting a hole in the floor.
Old Aug 21, 2012 | 08:59 AM
thats not good. you should check your hangers. yes its stock muffler deleted
Old Sep 5, 2012 | 07:57 PM
well the axle is not hitting the exhaust. the bushings apear to be in good shape. thinking of takeing out my full size spare maby thats what it is. sounds metal like tho. no signs of wear on anything to give me a clue. did this on stock springs as well
HEATON
Oct 16, 2015 07:21 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Tupp
Sep 30, 2015 08:18 PM
nathan112i
Sep 30, 2015 07:12 PM
Delta coupe
Sep 30, 2015 08:11 AM
