Rear wheel hop going around bumpy turns and stops???
Old Mar 14, 2013 | 12:43 AM
90TGP's Avatar
I have an '07 G5 GT with stock suspension, wheels and tire size. Nothing has been modified to the car.
I've been noticing recently that if I take left hand turn [at an intersection] at normal driving speeds and there happens to be some bumps [not big potholes] in the turn, my rear wheels like to hop or skip. Also, if I come to a normal stop and there are some bumps, the rear will hop/skip. I came to a stop today at a light, and it appeared that my front wheels hopped as well. It caused the abs to send the pulses through the pedal briefly like I was on ice. The hopping isn't violent, but does not feel right either.
Is this a known issue? I do live in NE Ohio, so the car has seen a lot of rough roads. Could the shocks be going bad? I have about 40k on the stock shocks.
Old Mar 14, 2013 | 11:35 AM
Hockeyman's Avatar
You said it. Your shocks are likely blown and need immediate replacing.
I had a rear shock blow and separate on the passenger rear, got those same hops you mention.
Solaris99
28
Mar 15, 2017 01:22 PM
biniecki
Oct 25, 2015 02:23 PM
DANRICKARD
Oct 1, 2015 12:08 AM
