Removing Heatshield
Old Aug 29, 2012 | 06:07 PM
brickloaf's Avatar
Removing Heatshield
Has anyone removed their heat shield with any issues? Im on B&G's and I scrape pretty often. This causes my heat shield to become loose which makes the heat shield rattle like there's no tomorrow when I am playing my subs. It seems like the heat shield comes loose every 4-6 months and I have had screws put in the heat shield countless times to tighten it up.
Soooo, my question is, can I remove the heat shield w/ no issues? Or is it protecting something that will get damaged easily if I scrape w/out the heat shield on??
Thanks!
Old Aug 29, 2012 | 06:11 PM
EXsoccer1921's Avatar
heat shield on the header? yeah. that or just put some loctite blue on them and tighten them down.
Old Aug 29, 2012 | 06:13 PM
brickloaf's Avatar
I mean the heat shield on the bottom of the car under the driver/pass seats. I dont think we are thinking of the same things
Old Aug 29, 2012 | 06:23 PM
ohhhh the exhaust heat shield.
Old Aug 29, 2012 | 06:35 PM
emiller's Avatar
What's behind the heat shield? The cats and exhaust get pretty hot. I'd want to keep that heat out of the car.
Old Aug 29, 2012 | 06:37 PM
brickloaf's Avatar
the heat shield is on the very bottom of the car....it basically stretches from wheel to wheel front to back and it covers everything behind it so I cant see....
Old Aug 31, 2012 | 01:19 PM
brickloaf's Avatar
anyone else have any input? Im wanting to take it off tomorrow.
Old Aug 31, 2012 | 10:11 PM
I'm fairly certain no one has any idea what this heat shield you speak of is(not trying to be a dick, just trying to help answer your question), post a pic that might help. Because all that I can think of the goes front wheel to back wheel and between drives and passenger side is the unibody frame, which shouldn't be loose or rattling
Old Sep 1, 2012 | 11:43 AM
08G5GT2.4L's Avatar
Mine did get bent up and rattled but I fixed it. I wouldn't remove it. Unless you want to potentially melt or start a fire from the heat. Not saying that would happen for sure, but it keeps a lot of heat from going to the floor of the car. I'd leave it on, and fix it better.
Old Sep 1, 2012 | 11:55 AM
ultimategnar's Avatar
its there for a reason. GM doesnt add anything they dont have to haha. just use lock tight
Old Sep 6, 2012 | 05:24 PM
Mindrot's Avatar
Originally Posted by ultimategnar
its there for a reason. Gm doesnt add anything they dont have to haha. Just use lock tight
x2
Old Sep 6, 2012 | 10:44 PM
x3
brickloaf
Show & Shine
56
Jun 18, 2019 12:51 PM
Turbo Johnny
Feb 21, 2019 09:41 AM
Extreme Dimensions
Sep 24, 2015 05:24 PM
katahdin_lubricants
Sep 20, 2015 07:24 PM
Getaway_Driver
Sep 8, 2015 09:41 AM
