replace control arm or just ball joint?
Old Sep 2, 2011 | 03:16 PM
OiangeSS's Avatar
ok so my pass side lower ball joint and i found some places that sell just the ball joint wanna know if anyone has replaced just the ball joint and how well it holds up or should i just replace the whole control arm
Old Sep 2, 2011 | 03:25 PM
rckrz6's Avatar
if you have the tools to do it then just do the ball joint much cheaper. they are pressed in
Old Sep 2, 2011 | 03:36 PM
OiangeSS's Avatar
i know i was just lookin to see if anyone has done it and how well it holds up
Old Sep 2, 2011 | 03:49 PM
blu3_v1p3r's Avatar
I have an LS and could have upgraded to better contol arms, but i opted for upgrading just the ball joint. I went with moog ball joints. I know the LS has different ball joints then the SS's do.
My ball join had three 1/2inch solid rivets in each one that were a PITA to drill and take out. It took about 2 hours on each one to drill and remove the rivets but once they were were out install took ten mins.
Old Oct 25, 2011 | 01:28 PM
LethalSS's Avatar
I have an LS ...
My ball join had three 1/2inch solid rivets in each one that were a PITA to drill and take out. It took about 2 hours on each one to drill and remove the rivets....
Ya it helps to grind them out if you have a portable grinder.
say has anyone done this on a ss/sc? rockauto.com has ball joints available separatly and for a fraction of the cost of the whole control arm. and I hate replacing stuff if its not bad... all I wanna do is replace the ball joint.
Old Oct 26, 2011 | 12:34 AM
87gn06gto07irl's Avatar
Drill? Grind? Man up and get the torches!
Solaris99
28
Mar 15, 2017 01:22 PM
biniecki
Oct 25, 2015 02:23 PM
justinchinn
Oct 2, 2015 12:18 PM
Trav3480
Oct 1, 2015 08:17 PM
Coballin13
Sep 25, 2015 08:43 AM
