Rotors do crack
Here's a better picture of it though. My other set diesn';t have the numerous "micro-cracks" so I really wish I knew which was which...
I only swapped out one yesterday since I have a brand new OEM set on order. I'll take a pic of the two off the car, which I believe is one of each. I'm just not 100% positive...
A lot of sticky weights on that rim bro. Good god. Solid rotors are not better than drilled ones for stopping on the track. That's ridiculous. Buy some expensive drilled or slotted rotors and some better pads and you won't crack them. For metal to come apart like that from heat, tells me your rotors are cheap and don't dissipate heat at all.. all the high end sports cars I've ever seen have drilled rotors. I'm sure they have it right.
Show me the link to a quality 5x110 drilled rotor that'll fit a TC. All of the aftermarket drilled rotors I've seen start out with a cheap solid rotor. Only upgrade I know of is Powell's floating rotors which I'll get next year.
Because they don't exist...
Good point! See, the thing is, that I plastidipped a set once (on the car) the night before going to a car show. I'll see if the black paint comes off on one or the other.
