slammed + base auto how to beat axle bind?
Old Sep 21, 2012 | 11:57 PM
  #101
Shogokuma's Avatar
i truly think it has to do with all 4 motormounts, especially the one underneath the fusebox
Old Sep 22, 2012 | 06:57 PM
  #102
YelloEye's Avatar
Raise the motor or raise the suspension back up. Axle bind isn't something that just goes away.
Old Sep 22, 2012 | 07:08 PM
  #103
znew's Avatar
I know that I keep bumping the thread because Powell is supposed to be making custom mounts...
Old Sep 22, 2012 | 10:41 PM
  #104
YelloEye's Avatar
Powell will let you know when he's got anything. You don't need to keep bumping it.
Old Sep 22, 2012 | 11:09 PM
  #105
znew's Avatar
why don't you worry about yourself and ill keep doing what I please
Old Sep 23, 2012 | 02:57 AM
  #106
YelloEye's Avatar
I'm just letting you know how Powell operates, if you wanna take it personal that's on you but you won't hear from Powell unless he's got something. Trying to pick E-fights won't get you anywhere either.
Old Sep 23, 2012 | 12:09 PM
  #107
Fitz88's Avatar
i gave up on powell zach
Old Sep 29, 2012 | 01:01 PM
  #108
RandyO's Avatar
the issue is shorter axles wont work, when you drop the car to extremes the long axle on the automatic passenger side crashes into the frame rail.
like Blazin says, raising the motor works, and I have a request in from a patient customer to do this, but it cant happen overnight I have way too much stuff to do with the race season upon us...I will try to do an a/t car here ( I have one) and bring the mounts out to CED....
Who is that patient customer? lol
So are we sure that shorter axles wont help at aqll? becasue even with my car dropped to where I would not be able to physically drive it, it doesnt seem as though the axle would rub the frame.
Old Oct 3, 2012 | 11:18 PM
  #109
Shogokuma's Avatar
FIXED IT FOR GOOD, traded the car in for a family sedan..
just couldnt stand it anymore tried everything for over a year, i just wish i new what it was..
Old Oct 3, 2012 | 11:23 PM
  #110
RandyO's Avatar
My bind has gotten significantly better over the past couple of weeks. I'm scared. lol I think I might just take the lock rings out and finish these axles off. hahah
Old Oct 4, 2012 | 07:05 PM
  #111
breds2k's Avatar
I gave up too, im gunna grab some b&g springs to go a tad lower but thats it.
Old Oct 4, 2012 | 08:51 PM
  #112
Powell Race Parts's Avatar
exactly.
Old Oct 4, 2012 | 08:54 PM
  #113
good for you. lowering the car to extremes without dropped spindles does not work. sucks that folks cant.wont.dont. want to beleive that. and the alternative solutions are a lot of work and money that folks dont want to pay for....all the best
Old Oct 5, 2012 | 04:41 AM
  #114
OttawaMark's Avatar
So are auto mounts now off the Powell radar? I'm running TTR polys, not horrible but a poor man solution to a problem that thus far not one single vendor has successfully solved. AFAIK, you are the only one to make the attempt.
Old Oct 5, 2012 | 05:58 PM
  #115
znew's Avatar
so basically we are screwed then since no mounts are being made. Bout to just take a page out of the miata handbook and throw some washers in to raise the motor up if that is the only way to fix it.
Old Oct 5, 2012 | 08:17 PM
  #116
mounts are not off my radar, but how many things projects etc can I invest time and money in for no big return? So far about 1 am to 6 am is the only time free.
I have several rear disc conversions here for drum braked cobalts. sold two.
and philosphically I think you want to be that low, you should bag it, but be prepared to fab the drop.
Old Oct 5, 2012 | 09:42 PM
  #117
OttawaMark's Avatar
I'm pedders low, soon to be Powell low and I just want a good non voided mount that is stiffer than the oems, of which I've been through 2 already. If it lifts the engine a bit, so be it otherwise ill take what you build and rattle a whole lot less than poly.
Old Oct 5, 2012 | 09:43 PM
  #118
znew's Avatar
Well i appreciate you looking out for us. I do know of at least 3 of us base model guys that would be interested in the mounts asap.
Old Oct 5, 2012 | 10:09 PM
  #119
blazerlow's Avatar
I'm not auto and I don't have axle bind but I'm concerned that my axle angle has worn out the bushing in my trans diff. Axle seals leaking one after another. If it is the case I will be getting it fixed on warranty but I don't want it to happen again. I am going to purchase the rotated F23 trans. mounts but I am curious if I could run those in combination with raising the engine mounts.
Also someone mentioned the brake line being close the axle. I noticed my axle has rubbed the brake line a few times when hitting bumps with my car lol. I gently pushed the brake line up a little to prevent it from happening anymore.
Old Oct 6, 2012 | 12:25 AM
  #120
Fitz88's Avatar
im guessing im one of those 3 ppl zach?
Old Oct 6, 2012 | 08:50 PM
  #121
RandyO's Avatar
Im down to fund whatever is needed within reason. Just let me know what I need to do John.
Old Oct 6, 2012 | 11:15 PM
  #122
Crav3's Avatar
How much are the brackets to bolt up the rotors in the rear? Im thinling of doing rear disc brakes later on but wanna get a price on the brackets
Old Oct 18, 2012 | 04:13 PM
  #123
2009CobaltLT's Avatar
ooo are those rear disc conversions for the 4 lug? how much?
Old Dec 18, 2012 | 04:39 PM
  #124
Steviodaddio's Avatar
I think everyone would just save themselves and Powell the time and money to just do a manual swap if it's as easy as others have said to eliminate axle bind for manual trans. lol
Old Dec 18, 2012 | 05:22 PM
  #125
Fitz88's Avatar
haha thats like 10x as much time and money
