spacers and extended studs
ive had quite a few stock wheel studs break on me and want to upgrade. i plan on buying these extended studs
ARP 100-7701 ARP Wheel Studs
and these spacers
15mm HUBCENTRIC Wheel Spacers CB: 57.1mm 4x100 4x108 Audi BMW VW Saturn Dodge | eBay
seem like a good setup?
and these spacers
Do not get the 7/16 thread.. I fucked up and got them since an guy named mornoat on here said it would work, got them and the threads was to small to fit in our hubs and just spun and never got tight..
I even had to buy lugs for that thread size so ended up ******* myself good.
So go with an 12x1.5 thread man
Any studs with 12x1.5 will fit
7/16 wont work with the hubs trust me lol
I have 10 of those studs with 20 spline drive lug nuts in my garage. I found some studs at the autopart that were 12x1.5 that was longer then stock. I run 15mm but cant remember the part number for them.
Look up the knurl size, you can get different size studs with the same thread. The Cobalt uses something around .470" I believe, haven't looked recently. You can go with an aftermarket stud that is larger, but you'd have to open up the holes in the hubs slightly.
do you have universal wheels? You should be able to use wheel spacers if you have wheels that are drilled for 8 lug, because where on normal wheels you need to cut your studs to fit, they will poke through the un used lug holes.
hope that makes sense, you should be able to use some 15mm wheel spacers, with the studs already built in if you have the spacing in the wheels.
Turbo Johnny
Feb 21, 2019 09:41 AM
