Spring Handling
Pedder springs ss/tc strut combo is the best you can get aside from a few good branded coilovers
off topic. role models, awesome movie
this is what you need to do on the car
coilovers - stance OR cheaper option go with pedders and fe5 struts.
powergrid adjustable sway bar links
powell rotated mounts
powell spherical cabs
powell derlin bushings
powell rear twisting beam spherical bushings
powell 1.25" sway bar
stock front bar
should be good there lol
all honesty if you want the best spring for handeling its either going to be pedders springs or the eibach prokit with fe5 struts. pro kit gives you .5" in the rear though and thats it so pointless. i had h&r springs and the ride is horrible and the handeling is no where close to stock, my buddies eibach has the same issue and all the other springs are junk except pedders.
stock front bar
haha alright iam trying to absorb this all in so in relaity pedders with a nice rear sway bar would take the the turn better then eibachs and whatever rear sway bar guessing the ottp hardcore
nah i ust want something thats gunna be a few stepups from stock :O). like if for some reason i see like 9 cones ina line iw anna zip ina nd out of em haha i tried doing that doing like 40 on a highway turn and it didnt turnout so well
boosted09 prolly has the best idea but the most expensive. i got k sport springs, strut bar, and rear sway bar. works well for the **** i do. eventually im gonna rebuild my suspension to make my car into an auto x ride
why do you say that? springs are perfectly fine if you find the right spring/strut combo. coilovers are always a bit better since you have the adjustability but not everyone wants to fork out the cash for them. pedders and fe5 struts would do you well.
well it depends. in some classes ive seen some coilovers will equal certain higher end strut spring combinations as far as points go BUT if you get a real baller set of coilovers you will alter your class substantially.
DANRICKARD
Oct 1, 2015 12:08 AM
