Spring question
Old May 29, 2008 | 08:51 PM
outtamymind's Avatar
depends on the place you take it to. i know ours is like $150 for the alignment and we do lowered cars all the time. and anytime you do any suspension modifications you should always get an alignment. which is why you should do all of your suspension mods at the same time and not within a week of each other as that can get quite expensive.
Old May 29, 2008 | 09:29 PM
typo's Avatar
can you guys confirm the drop? of SS/SC springs on a 2.2?
Old May 29, 2008 | 09:33 PM
nope. but their would be a drop in it though. how much dunno
Old May 29, 2008 | 09:36 PM
bridfi's Avatar
1. expect to replace struts soon if you drive your car like a madman over bumps and railroad tracks
2. during the install, make sure the front tabs on the struts are facing in toward the engine
3. you'll love the new look and feel of them
4. expect about a 6 hr install. thats how long it took me and im not exactly stupid...
Old May 29, 2008 | 09:38 PM
typo's Avatar
decent drop, i was gonna go all aftermarket springs and struts but i really dont want that much drop.. i just wantt o lose the off road look, i got 18's on my car what do you have on your car?
Old May 29, 2008 | 09:45 PM
bridfi's Avatar
17's
Old May 29, 2008 | 09:52 PM
here's pics of mine with the ssc lowering springs. i have the stock 17" rims.
before and after
front
back
sorry about the dirty car but it just stopped raining and i wanted some new pics.
Old May 29, 2008 | 10:36 PM
D4u2s0t's Avatar
about a 1/2 inch or so. but that 1/2 inch makes a big difference.
i can do it in about 2 hours with handtools. with air tools, would probably be about an hour, most likely less though. shouldn't take anywhere near 6 hours though.
Old May 29, 2008 | 11:19 PM
znew's Avatar
ok now when i buy springs all i need are lowering springs right. My buddy was telling me that he had to get camber plates with his kit for his mustang. i have no idea what i need. Need some help
Old May 29, 2008 | 11:51 PM
stweed's Avatar
roughly how much would new struts cost?
Old May 30, 2008 | 01:17 AM
  #36
D4u2s0t's Avatar
minimum of about 600 new.
Old May 30, 2008 | 11:56 AM
  #37
stweed's Avatar
wow thats a lot more than i was expecting i dont even know if i want to put my springs on now...
Old May 30, 2008 | 11:58 AM
  #38
D4u2s0t's Avatar
many members are fine with the stock shocks. you can buy brand new stockers for about 30/each or so, so even if you test out the new springs, and you blow a shock, you can get a new one cheap, and put the stock springs back on if you can't afford aftermarket shocks. springs retain their value pretty well, so you can always sell them afterwards if it doesn't work out for you.
Old May 30, 2008 | 12:03 PM
  #39
stweed's Avatar
that helps me out a lot thanks. how will u know if a strut is leaking?
Old May 30, 2008 | 12:06 PM
  #40
b_faulk75's Avatar
I ran my sportlines for over a year without an alignment and had NO tire wear, i know it seems hard to believe but it's true. When i took them off only one rear shock had blown, the front looked fine, atleast no leaks anyhow. On a side note, i did do an alignment after the airbag install, way to risky, but so far no issues with that either.
You will see oil or grease around the body of the strut, and your car will ride different.
Old May 30, 2008 | 12:07 PM
  #41
D4u2s0t's Avatar
you'll feel the difference in ride quality. a more advanced way to check would be to take the strut off, and see if it's leaking. a good strut will be able to be pushed and pulled in and out, and be smooth. there should be some resistance, but the biggest thing is that the movement is smooth, not jerky. if there's zero resistance, that's a bad sign. but basically, you'll know if you blow a strut when you go over a bump in the road.
Old May 30, 2008 | 12:13 PM
  #42
stweed's Avatar
ok thanks guys i appreciate it
Old Jun 2, 2008 | 03:25 PM
  #43
typo's Avatar
question, i purchased ss/sc springs off a local guy who said they were ss/sc springs and i put the back ones on and there isn't any difference in drop? also the tags tags ont he rear springs are purple and on the front they are white. I compared the fe5 spring part numbers from cratenginedepot.com to the ones on my springs and they dont match is there any way to confirm that they are ss/sc springs?
forget it gonan go ss/sc struts with prokit or koni with sport kit..
brandon04
Oct 21, 2015 07:04 AM
HEATON
Oct 16, 2015 07:21 PM
Tupp
Sep 30, 2015 08:18 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
Extremespeed
Sep 29, 2015 04:34 AM
