ss/sc parts on a 08 lt
Old Jul 18, 2008 | 06:23 AM
orde350's Avatar
has anyone tried putting the exhaust and springs from a ss/sc on a 08 lt. well i found a down pipe and springs i am picking them up tonight and trying to install them tomorrow. i will post my result
Old Jul 18, 2008 | 01:23 PM
YSUsteven's Avatar
2.0 LSJ to 2.2 L61 Swappable Parts
Many people have done it and have posted their results. Search
Old Jul 18, 2008 | 04:09 PM
orde350's Avatar
i tryed but i could't find anything in new to this!! so dont be an ass
Old Jul 19, 2008 | 02:36 AM
picsbypenny's Avatar
did u get shocks and struts off the ss
and
hows it ride
i want to put the ss suspension on my 08 LS
i think i might try to get it done through GM to see if i can keep it under warranty
Old Jul 19, 2008 | 06:31 PM
Blue_Balt's Avatar
and
hows it ride
If you put the whole ss suspension on the car and something fails; it won't be under the warranty. Although the SS/SC or TC Suspension is made by GM, it wasn't put on the car right out of the factory nor is it an option from there. I'm still going to put either FE5 struts or go even higher with Konis when I lower my car.
It's a sticky in the 2.2 section.
Old Jul 19, 2008 | 07:07 PM
fe5?? is that the ss struts?
Old Jul 19, 2008 | 11:31 PM
Blue_Balt's Avatar
Yes,
It's the struts that are found on the SS/SC and TC
Old Jul 22, 2008 | 06:58 AM
orde350's Avatar
ok here is what i found. friday i bought 06ss/sc springs and down pipe. when i got home i found that mine had 2 cats and 2 o2 sensors (one before the cats and ane after)and the one i bought had only 1 cat (good thing) but only one o2 sensor after the cats. but this can be fixed you just to get a fitting and fab up a new o2 sensor port before the cat. I have no idea if that will work im going to try next weekend.
now for the springs thay will slam right in!! with all the right tools at hand i had them in and the car on the road in 2 hours flat. the car did get lowered some maby and inch or so but the handeling is so much better.
Old Jul 22, 2008 | 08:50 AM
OrngBalt's Avatar
you can get a new bung welded in for trhe second sense.... shouldn't cost you more than say... $40-50.
the spring will even you out more than anything. Drop is minimal, but helps the look and definitely helps the handling.
Old Jul 22, 2008 | 08:56 AM
orde350's Avatar
hell with that i do ALL my own work!!! i will slap that thing in in no time.
Old Jul 22, 2008 | 08:02 PM
any ss in the dfw getting rid of their suspension?
Oct 20, 2015 09:56 PM
HEATON
Oct 16, 2015 07:21 PM
justinchinn
Oct 2, 2015 12:18 PM
dieGone
Oct 1, 2015 06:27 PM
metroplex
Sep 27, 2015 07:48 AM
