Stance coilover question
So installing the rear springs quick question theres the bottom mount on the spring then the actually spring then the top mount for the stance coilover setup does it go
bottom mount , perch , spring , top mount? my only concern is when i put the spring directly on the perch there was a little play figured it would go away when everything is tight but wanted to ask thanks in advance a picture would be great!
Great i just wanted to make sure because there was just a little play in it i figured once it was tight and on the ground it would be good but just wanted to make sure i just have them on the highest setting right now doing the front tommorow they are sick!
