Stance coilover question
Old Nov 19, 2011 | 09:10 PM
1 SLOW SS's Avatar
So installing the rear springs quick question theres the bottom mount on the spring then the actually spring then the top mount for the stance coilover setup does it go
bottom mount , perch , spring , top mount? my only concern is when i put the spring directly on the perch there was a little play figured it would go away when everything is tight but wanted to ask thanks in advance a picture would be great!
Old Nov 19, 2011 | 09:12 PM
ericgt79's Avatar
yes. when the car is on the ground it will be tight dont worry, just make sure you got them even as possible
what i did is count threads and matched them up
Old Nov 19, 2011 | 09:14 PM
1 SLOW SS's Avatar
Great i just wanted to make sure because there was just a little play in it i figured once it was tight and on the ground it would be good but just wanted to make sure i just have them on the highest setting right now doing the front tommorow they are sick!
brandon04
Oct 21, 2015 07:04 AM
OrangeCoba
Oct 1, 2015 10:00 PM
soaxin
Sep 26, 2015 08:41 PM
soaxin
Sep 26, 2015 08:39 PM
