★★★ STANCE Suspension - ULTIMATE REVIEW THREAD ★★★
Old Aug 7, 2012 | 01:42 PM
Nfamous60's Avatar
RK Ramos that turbo badge is off the 911 right?
Old Aug 10, 2012 | 02:41 AM
Nfamous60's Avatar
how many of you have done track days with ur stance coilovers?
Old Aug 16, 2012 | 10:15 AM
Miles Power's Avatar
Originally Posted by Omnigear
^this, had the stance. they are soft in the rear. they are a good street coils and i guess you can track them. you can get swift springs with them with higher rates on the rear but you will prolly need to get the shock revalved for em..
bottom line i would recommend it for the avid user not for track use.
I agree they are soft in the rear but then I don't have them fully stiff. With the street and dirt road going home is makes somewhat unpleasent... Pretty fluent on any other street near Katy-Houston area. For the next part sways, and strut brace.
Old Aug 16, 2012 | 10:18 AM
Omiotek's Avatar
the springs are still too soft for the rear
Old Aug 16, 2012 | 10:25 AM
thmotorsports's Avatar
What are you guys setting the rebound at?
Old Aug 16, 2012 | 10:48 AM
Omnigear's Avatar
i had it from max to soft, drove the same patch of road
Old Aug 16, 2012 | 12:01 PM
Omiotek's Avatar
ive had it all over the board. like ive said prior they arent a bad street shock or a street setup but they could use a stiffer spring out back. usually front drivers run a little bit stiffer out back and a bit softer up front where as AWD is stiffer up front then out back
Old Aug 20, 2012 | 03:52 PM
GoofyBalt's Avatar
The quality seems really nice for the price, the only complaint i have is the rear is way too soft. I have all rings on and low as possible, nearly tucking tire, about 1/4 from tucking and i bottom out a lot in the rear. I have the fronts on 9 and the rears on 7. I wouldnt reccomend them to anyone until they come with a stiffer spring in the rear. I will be ordering different springs for the rears and have the shock revalved.
17" XXR 527's +25 offset.
215 45 17 Tire
Old Aug 20, 2012 | 04:06 PM
widowedeight's Avatar
Originally Posted by RKRamos
Like my buddy I also had dreams of going low, I felt as if I met my intended power levels and decided to take a new outlook on my car. With Stance and fitment EXPLODING onto the car scene I decided to take a stab at it.
Setup: Stance GR+
-Front: One locking ring removed.
-Rear: Both rings removed/Bump stops removed
Wheels: 17X9 Enkei PF01SS
Tires: 215/40/17 Yokohama S. Drive
Photos:
RKRamos91, on Flickr
Love the roof rack!!!!
Old Aug 21, 2012 | 06:46 PM
Soft for now, but I kinda being lazy right now. Soon I'll be stiff'n it up more after I have new tires for the rear.
Old Aug 21, 2012 | 06:51 PM
  #36
215 45 17 Tire
Hey those are the 8.25 wide right. I haven't seen anyone with the 9.75 wide on the four lugs.
Old Aug 21, 2012 | 07:17 PM
  #37
Omnigear's Avatar
stance didnt listen the first time the rear spring was addressed for being to soft..
Old Aug 22, 2012 | 06:35 PM
  #38
Where do you have the rebound adjustment set at?
Old Aug 23, 2012 | 10:47 AM
  #39
Finally got to re-adjusting the rear and its better now then before. But I have to say doing this coilovers will got some looks. I even had to thank the guy in the G5 last week for his "Thats a good job" complement-while driving windows done-.
Old Aug 23, 2012 | 11:46 AM
  #40
GoofyBalt's Avatar
Miles Power - Rim size is 17x8.25 +25 offset.
Old Aug 23, 2012 | 01:28 PM
  #41
Omnigear's Avatar
had it from all soft through full and at max height it didnt matter.
a homie that had stance also put 10k in the rear
and bam problem solved.
Old Aug 23, 2012 | 01:31 PM
  #42
10K Rear spring from where?
Old Aug 23, 2012 | 09:03 PM
  #43
znew's Avatar
i need a stiffer spring these 4ks do nothing for me. so soft!
Old Aug 25, 2012 | 12:06 PM
  #44
These look great on the coupe. But some people think I should try to run the 9.75 wide on mine cause I will make it look more agressive. But I feel like it would poke a lot and ride like crap.
Old Aug 25, 2012 | 12:28 PM
  #45
Jookycola's Avatar
Don't do it. 9 inch wheels on rolled and pulled fenders look great with the right backspacing. But 9.75 is just too much period. It won't look good trust me I had 9.75 XXR's and bolted them up and they stuck out way bad. Bad as in looking retarded, not bad like in really cool.
Old Aug 25, 2012 | 02:02 PM
  #46
Omiotek's Avatar
I run 245 40 18s with Xxr 527s 35 offset its aggressive enough...still need to be rolled with a very minor pull
Old Aug 25, 2012 | 02:20 PM
  #47
heeter_33's Avatar
Subd for future coilover purchase
Old Aug 26, 2012 | 10:04 PM
  #48
See this is what I was afraid of. I guess I'll figure out what to go with for later. Although, I like to go with a 9in wide so I'll keep looking.
Old Aug 29, 2012 | 10:13 AM
  #49
GoofyBalt's Avatar
yea the 8.25 with the +25 offset make my car sit really really flush, i have rubbing issues too. I cant imagine have 9.75 on there, it would look stupid. If the 8.25 isnt enough you can always buy spacers. Also my fenders are rolled and they still rub pretty good.
Old Aug 29, 2012 | 11:34 AM
  #50
dayhoff35's Avatar
im also currently looking for stiffer springs
