Steering Knuckles
Old May 27, 2010 | 11:44 PM
j27-2's Avatar
Steering Knuckles
what are my options for upgraded front knuckles. I have an ls sedan with 4x100 bolt pattern. do ss/tc knuckles fit and what about ones from a G6 instead of the GM Knuckles for Competitive Driving?
Old May 27, 2010 | 11:48 PM
ls1fbody's Avatar
Haz l33t wheelz.
your axles won't fit into the SS/TC ones.
Why upgrade? you have the same knuckles as an LSJ. Until you break one, which is unlikely, don't bother.
Old May 28, 2010 | 12:43 AM
j27-2's Avatar
I would rather eliminate the possibility.
Old May 28, 2010 | 01:30 AM
Stamina's Avatar
The G6/Competition Knuckles should work I'd imagine. After all, they were designed for the SS/SC.
According to Powell, the Competition knuckles appeared to have a better casting than both the SS/TC and SS/SC knuckles. In steering ratio, the SS/SC is slowest, Competition is middle, and SS/TC is fastest.
Here's the thread where quikredline (Powell) talks about the Cobalt's suspension, knuckles being one of the topics if you scroll down a bit. https://www.cobaltss.net/forums/suspension-67/thoughts-cobalt-front-suspension-202915/
From left to right: SS/TC, Competition/G6, and SS/SC
Old May 28, 2010 | 04:02 PM
BlackyK's Avatar
Boy those Comp knuckles look amazing.
Old May 28, 2010 | 04:06 PM
rallyracer's Avatar
G6 ones will be mine soon!
Old May 31, 2010 | 03:42 PM
Maven's Avatar
G6 knuckles require mild machining to fit the hub properly.
SS/TC knuckles also require machining to fit a non SS/TC hub, but there isnt enough material to safely machine them.go with modified G6 knuckles from Powell or GMR Comp knuckles if you can find them still.
But as was mentioned, knuckles dont break under anything even remotely close to normal driving or even auto-x/track day use. No real "need" to upgrade.
Old Jun 1, 2010 | 01:50 AM
PenguinPIE's Avatar
i have also heard people saying breaking them is unlikely in autox but there is a sticky in the autox forum that says the GM test car broke it during autox? i just want to make sure i dont need it
Old Jun 1, 2010 | 04:34 PM
Maven's Avatar
GM did NOT break them during autox......they broke ONE knuckle, during very serious extremely high load testing on GMs road course (google map Miolford proving ground) there a 30+ degree banked concrete corner thats Nurburgring style.
Old Oct 18, 2023 | 07:14 AM
Gary Grizzle's Avatar
2009 passenger knuckle 25923941
Where can I get a 25923941passenger knuckle replacement
Solaris99
28
Mar 15, 2017 01:22 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
TedSS
26
Oct 10, 2015 04:30 PM
importkiller
Sep 30, 2015 07:18 PM
