suspension issue
Old Jul 26, 2010 | 10:54 AM
yellow dragon's Avatar
suspension issue
So whenever i hit a bump in the road (which in winnipeg is all the time) I hear like a loose rattle sound in the front end seem to be coming from the passenger side, and when I am in a tight right turn and braking I hear a grinding growl from the back. Anyone have any ideas what I should look for when i take off the wheels to see. FYI I have no suspension mods or brake mods.
Old Jul 26, 2010 | 11:29 AM
Stiner's Avatar
The front end noise is most likely either your sway bar end links or your control arm bushings. not 100% sure on the rear end problem but I'm guessing is brak related
Old Jul 28, 2010 | 03:28 PM
2006CobaltSS12's Avatar
mine does the same thing. My rear brakes are getting bad but I already have the pads to be put on. My front end does the same thing as well. But I am at 66K miles so I'm replacing my shocks and struts as well because I can just press down on the hood and the whole car moves. We will find out if all of this changes when I replace it all. I'll keep you posted. It may take me a couple weeks so please be patient.
Old Aug 4, 2010 | 02:20 PM
I have a recent update for you. I went to a quick stop oil and lube shop and they said it may be my lower A-arm or bushings. I went to them just for a quick opinion as I was on my way to work. I am getting a second opinion on Monday morning from the shop I go to for major repairs like that. I will keep you posted.
Jan 12, 2016 12:01 AM
OrangeCoba
Oct 1, 2015 10:00 PM
Trav3480
Oct 1, 2015 08:17 PM
Tupp
Sep 30, 2015 08:18 PM
yellow dragon
Sep 28, 2015 09:49 PM
