Suspenson basics 101.
Old Mar 30, 2013 | 08:56 PM
  #126
emiller's Avatar
Is the spring seated correctly with the isolator in place and not broken?
Old Mar 31, 2013 | 10:03 AM
  #127
zzCobaltSSzz's Avatar
You mean the isolator as in the piece at the very bottom of the spring? It's not broken but the end of the spring is maybe 1/4"-1/2" away from the notch? Not sure how close that has to me and I greased everything up this morning and replaced a strut mount but still no luck:/ no clue on what to do except take it all back out or take it somewhere to look at it
Old Apr 2, 2013 | 07:17 PM
  #128
well after buying and replacing both strut mounts i found the problem was with the swaybar endlink somehow got loose...so its riding smooth now
Old Mar 23, 2014 | 01:57 AM
  #129
88lude's Avatar
Anyone know the best lowering springs?
Old Mar 23, 2014 | 10:00 AM
  #130
Personal opinion.
Old Mar 23, 2014 | 10:17 AM
  #131
Joe09SS's Avatar
Seems like people usually like Powell's or eibach the most
Old Mar 23, 2014 | 09:14 PM
  #132
andrewcarr1993's Avatar
Best low spring? Best performance springs or best one that's a balance of low and handling. Low would be G&G or H&R (but at that point I'd say just splurge on coilovers) best handling is YYZ although it won't lower you that much and a nice mix would be SSC springs which are really close to the same as CM springs.
Old May 1, 2014 | 08:02 AM
  #133
strikertaylor10's Avatar
I'm dropping mine 2" and 2.5". Without a camber kit is the camber really noticable? I mean to the eye? I Will deff get an alignment and toe adjust. I just wanna know will it camber my tires so much that it will be highly noticeable to the eye?
Old Mar 16, 2015 | 12:13 PM
  #134
FL08LS's Avatar
Possible dumb question.
Just got some B&G Springs put on a few days ago. I do have a subwoofer in the trunk weighing maybe 90-100lbs (heavy I know). The back sits lower...somewhat expected maybe and audibly rubs when driving around. This is very frustrating as that is the only thing in my trunk and should I ever truly load it up for any reason it would get pretty bad.
Onto the actual question. The B&G springs have 2 springs that have a compressed end of sorts that stretch out and 2 other springs that are moreso evenly stretched for a lack of a better word.
The springs are on and it will be a pain to swap front and back if need be but which springs are supposed to go on the front and which on the back?
I can try and provide pictures if need be but it would be stock photos found online.
bigdeertz
Nov 17, 2016 09:41 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
Extremespeed
Sep 29, 2015 04:34 AM
Trav3480
Sep 28, 2015 02:46 PM
