Suspenson basics 101.
Old May 14, 2009 | 02:09 PM
  #101
Maven's Avatar
Originally Posted by 68nova200
speaking of endlinks. can i run fe1 endlinks with fe5 suspension. just wondering because i am supposed to install my suspension friday.
Yup, sure can. I told your helper too
Old May 14, 2009 | 02:22 PM
  #102
CobaltSSilver's Avatar
I should have a pretty interesting little car after adding the lowering springs (I am thinking Cobalt-Addiction since they aren't too low on the front at .75 inch unless they are prone to sag early) the end links and then my other mods (ttr rear sway bar, bwoody rear bar, DC front strut bar, 235/40 tires)
Old May 14, 2009 | 05:40 PM
  #103
68nova200's Avatar
ok thanks.
Old May 14, 2009 | 05:48 PM
  #104
Anybody have experience with the CA lowering springs? I like the idea of Eibach for reliability and no sag but the CA springs down go quite as low and are said to have a better ride for about 40-60 bucks cheaper too.
Old May 17, 2009 | 02:08 PM
  #105
conerboner's Avatar
What coilovers are the best as far as being able to adjust and the smoothness of the ride? I really want to know before i spend over a grand on something like this. Thanks in advance.
Old May 17, 2009 | 02:12 PM
  #106
EatonTVS07's Avatar
thats alot to read
Old May 17, 2009 | 05:20 PM
  #107
I honestly can't tell you for sure, but I can tell you that all of them have a ton of settings to use. I would read through the forums not all coil over kits are created equal. Some folks have had issues on here with fitment.
Old Nov 24, 2009 | 06:52 PM
  #108
hamann80's Avatar
Originally Posted by Badmunky
Stock SS: This is a good set up and a good upgrade for the base cars. It will give you a good ride and still have handling that is beter then most of the cars in its class. And will beat most moded lower class cars as well.
I read your post but I'm not quite sure whether or not stock SS includes SS/NA or Sport with the SS/SC and SS/TC?? Do they both have the same upgrade? I know the suspensions are slightly different between the SS/NA and Sport when compared to the SC and TC cobalts.
Also, I read a post similar to this on another site saying that a 1.6" drop on a cavalier would require struts (preferably lowering struts). My main question is if there is a given limit on drop when you would need to get struts? I'm looking into getting the arkperformance lowering springs and they say 1.3" in the front and about 1.57" in the back (that's an approximation since they say -30mm front and -40mm back). If i'm correct in my thinking any lift is going to create extra pressure on the struts no matter how large the drop is.... right?
Old Nov 25, 2009 | 11:06 AM
  #109
Maven's Avatar
FE3(2.4L) suspension isnt different enough imo to make it worth "upgrading" too, when people talk about SS suspension, I would say its safe to assume that FE5(2.0L) suspension is whats being talked aout.
a 30/40mm drop wont hurt your struts/shocks unless you dive bomb over every bump you find, thats a relatively mild drop and the stock shocks will be just fine. Its not the drop that hurts them, its constantly bottoming out, or very hard bottoming.
Old Jun 30, 2010 | 04:06 PM
  #110
stoon_cobalt_colby's Avatar
hey guys i heard if u lower the car to much it will make the axels bind i believe and than easily break? anyone know about this i might get some B&Gs but they are lowest spring on the market and not sure if it will cause problems or not so if anyone knows please let me know i do go to the track once every 2 weeks so dont want axels to bind than snap so if anyone can help i would be very greatful
Thanks
Old Jul 8, 2010 | 11:32 PM
  #111
vahdyx's Avatar
Tirerack.com has struts for cobalt ss's now. We should update the sticky. I'll continue reading this long read now.
Old Jul 9, 2010 | 09:44 AM
  #112
RS75GT 1SS's Avatar
Nobody really addresses anti-roll bar upgrades in these pages. I've got a question about FE3 to FE5 front bar upgrades. On Crateenginedepot.com it lists two different types of brackets and bushings for the 24mm bar. Which do I need?
Old Jul 9, 2010 | 09:59 AM
  #113
the_cobalt_kid's Avatar
Sub'd and epic.
Old Aug 4, 2010 | 09:57 PM
  #114
ryman416's Avatar
lets drop this mo fo lol
Old Aug 5, 2010 | 04:54 PM
  #115
matt638's Avatar
would anyone happen to know which spring keep the ride close to stock? but give it the nice lowerd look?
Old Aug 6, 2010 | 10:33 AM
  #116
qwikredline's Avatar
pedders
Old Jan 27, 2011 | 03:37 AM
  #117
Stick's Avatar
Awesome write up, I just had a shopping list for new performance suspension parts.. You just saved me $150, now all I have to fork out is another $1,000.. Thanks again...
Old Aug 15, 2011 | 11:05 PM
  #118
2010Cobalt's Avatar
Nice
Old Oct 13, 2011 | 07:11 PM
  #119
Danny_Cin's Avatar
Sticky'er than sex with a 400lb women in the middle of the Sahara Desert. Hell of a write up.
Old Apr 19, 2012 | 05:30 PM
  #120
m33pm33p's Avatar
Question:
I have the option of cheap linear springs made in any weight and size I want. Being that they are linear would the shape of the springs interfere with either the front of back suspension on install. ei: will they clear the front struts and sit properly and will they clear the read bump stops properly and seat well?
They need od, id, spring rate and length of springs to make them. Being linear wouldn't they be the same size coils all the way down the spring, since companies use different coil sizes to produce progressive rate springs?
I also understand that linear springs don't "ramp up" and become harder as they compress. Are the stock cobalt tc springs linear or progressive. Have searched a lot but no solid answers.
Old May 3, 2012 | 11:59 PM
  #121
esink's Avatar
With coilovers, don't most of them come with a new strut now? Those kits have the whole thing, not just a sleeve, right?
Old May 4, 2012 | 04:59 AM
  #122
06cobalt racer's Avatar
yes that is correct
Old May 5, 2012 | 01:54 AM
  #123
esink's Avatar
Originally Posted by 06cobalt racer
yes that is correct
Okay thanks. I went through the first post (obviously new around here) and thought to myself: Why would I buy a new strut for a Coilover, if the coilover comes with a new strut ;P
Old Feb 28, 2013 | 04:57 PM
  #124
balt0man5's Avatar
so if i would put SS springs on my base models would it sit any lower?
Old Mar 30, 2013 | 08:40 PM
  #125
zzCobaltSSzz's Avatar
I've got a question, I installed megan racing springs on my SS N/A and have a squeaking but also like my spring is hitting metal or something? If anyone has any thoughts you can respond to this or email me theryansmithproject@gmail.com
