tips?
Old Mar 23, 2016 | 04:29 PM
basebalt's Avatar
tips?
Trying to replace my front shocks and struts. Only problem is the end link nuts just spin, they don't loosen or tighten, and the 4 strut bolts won't budge probably rusted in so they're soaking. Any tips to get these out?
Old Mar 23, 2016 | 04:32 PM
Get some vise grips I think they are called and see if you can hold it in place. If that doesn't work then your more than likely going to have to cut them off for the endlinks atleast
Old Mar 23, 2016 | 04:38 PM
basebalt's Avatar
Alright I'll try that thanks. Tried taking it off the sway bar because they need replaced too but I was in a rush and only tried with my 1/2" so I'll probably try that with my 3/8" as well
Old Mar 23, 2016 | 06:38 PM
double clutch's Avatar
On my moogs i slid the boot off and there was a square nut that i could put a wrench on to hold the stud in place
Old Mar 23, 2016 | 11:42 PM
basebalt's Avatar
Yeah I bought moogs to put on. These are the originals though. 100k miles of rust and wear. Tried everything, even heating them up but they're too badly rusted I guess so first thing tomorrow I'm buying new blades for my reciprocating saw and cutting em out. Thanks guys
Old Mar 23, 2016 | 11:44 PM
Did you let them soak with dw40 or something of that nature?
Old Mar 24, 2016 | 01:44 AM
basebalt's Avatar
Yeah. They've soaked all day lol they're practically welded to the stud with rust I'm assuming because nothings breaking it free.
Old Mar 24, 2016 | 10:12 AM
Lol damn cutting will be your friend then
Old Mar 24, 2016 | 12:26 PM
Go get a cutting wheel and cut it off from the swaybar side, and then you can leave the other part attached to the strut since you're replacing it.
Old Mar 24, 2016 | 12:28 PM
basebalt's Avatar
They're cut out. Cut them out at the sway bar because the nut won't move at all and they need replaced but they still won't so I guess it's either keep trying or drill em out lol. Gotta love pa winters.
Old Mar 24, 2016 | 01:09 PM
basebalt's Avatar
I used a reciprocating saw. Bolts still stuck to the sway bar so I might just drill it
Old Mar 24, 2016 | 01:11 PM
Go get a jell rust remover, cover the bolt ends and give it a few then rinse off they should fall out better. WD40 isn't that good at eating rust, just preventing rust for a period of time.
Old Mar 24, 2016 | 04:34 PM
basebalt's Avatar
I'll look into it thanks. I got one to break free just needs to break out. Other than that one sides done. Other sides still corroded in and ran out of time today.
Old Mar 25, 2016 | 10:30 AM
basebalt's Avatar
Soaked the remaining end link studs and the passenger side knuckle studs in pb blaster and still nothing. Is that gel at lowes?
Old Mar 25, 2016 | 10:35 AM
Might be, hit up a parts store they'll def have it
Old Mar 25, 2016 | 08:15 PM
basebalt's Avatar
Alright I'm going to have to go to napa anyways. These bolts are done due to corrosion and how hard I had to hammer em. Anyone know the part# because I can't seem to find em or would any number 120 bolt do?
Old Mar 26, 2016 | 09:16 PM
basebalt's Avatar
Cut the top bolt out since it wouldn't budge and grinded the remaining end link studs. Rides nice, smooth and the steerings so much tighter. Thanks for the help guys.
Old Mar 26, 2016 | 09:43 PM
Glad you got it all installed
Old Mar 27, 2016 | 01:37 AM
basebalt's Avatar
Thanks man me too. Only thing I hate about doing my own work is running into these stupid issues and getting stuck for a bit haha.
Old Mar 27, 2016 | 02:02 PM
Haha yeah but it's alot cheaper to do the work yourself
Old Mar 27, 2016 | 02:09 PM
basebalt's Avatar
True and usually at least for me more enjoyable. Have to redo the drivers side because according to my brother in law I put the top insulator in upside down and the bearings on top instead of under but that's a quick fix and rookie mistake. Thought that's how it came apart but oh well
SSxTc0825
Nov 14, 2020 02:05 PM
CudaJoe
Apr 18, 2016 10:39 AM
09SS7163
Mar 28, 2016 11:44 AM
SSxTc0825
Mar 27, 2016 12:30 PM
DarrenGC
Mar 22, 2016 04:48 PM
