track differences between sedan and coupe
Old Aug 10, 2010 | 04:08 PM
stangetr's Avatar
when looking at specs i found that the front track width is different between the coupe and sedan,
what makes them different?
a-arms? wheel bearing, knucles?
when swapping parts this could make a differance, if anyone knows please let share
i've swapped subframes between coupes and sedans with no problem so i'm guessing its withing the suspension components, maybe thats why my car pulls to one side on the track, could one side be shorter than the other? even after countless alignments 1.2" per side is significant
Front track (coupe) 57.1 in (1,450 mm)
Front track (sedan) 58.6 in (1,490 mm)
Old Aug 10, 2010 | 04:26 PM
Illini_06SS's Avatar
I'd like to know where you're getting those coupe track widths measurements from. I'm seeing 58.7" Front and 58.1" Rear for both. (From autos.yahoo.com)
Old Aug 10, 2010 | 05:23 PM
Wangspeed's Avatar
The front and rear suspension components are the same for both. However, you need to make sure you run the same model components on both sides, like FE5/FE5 and not FE3/FE5.
Old Aug 11, 2010 | 03:29 PM
stangetr's Avatar
wikipedia
Old Aug 11, 2010 | 05:33 PM
Originally Posted by stangetr
wikipedia
I found your problem.
All Cobalts have the same track width, according to GM. (Go to the "Dimensions" tab)
http://www.chevrolet.com/cobalt/coupe/features-specs/
http://www.chevrolet.com/cobalt/sedan/features-specs/
turbochargedss2012
Sep 20, 2023 12:17 PM
biniecki
Oct 25, 2015 02:23 PM
Oct 13, 2015 09:32 PM
maliki778
Oct 1, 2015 07:39 PM
Extremespeed
Sep 29, 2015 04:34 AM
