Tributes 08 'balt drum to disc + brembo + 5 x 114.3 conversion
Old Sep 17, 2011 | 10:52 PM
Powell Race Parts's Avatar
well. It turned out to be a long day, totally unexpected. Tribute's wheels, claimed by the wheel maker to be 5 x 114.3 and 4 x 100. are not.
4 x 100 yes, thats how he drove in.
not how he drove out.
the Brembo conversion went well.
the rotors are machined along with new bearings to 5 x 114.3 and coated in VHT paint. Knuckles are pre-prepared on an exchange basis
size is a nice upgrade, 265 mm to 315 mm.
Mike chose candy blue Brembo calipers
the rear LSJ conversion is complete (dust shields ommitted due to opening statement and ensuing lawlz)
the full kit comes with steel lines, flex lines , brackets, hand brake cables the whole enchilada
once installed and brakes bled, borrowed some wheels
who said 18 x 9.5 wont fit a slammed Cobalt?
and went to my fave tire and wheel guy and got a very good deal on msr 17's that clear Brembos without a spacer, and some super hot high performance Continental extreme all weather tires.
Color Tribute happy and paint him lighter....
his wallet is almost as lite as carbon fibre
If you want to find out more and get all or parts of our conversion kit for drum brake rear cobalts, contact gloria or john@powellraceshop.com. Kits start at a base price of $225.00. The cost escalates sharply as you add more and more options.
Old Sep 17, 2011 | 10:54 PM
Dart_SI's Avatar
looks good
Old Sep 17, 2011 | 10:58 PM
09sscalicobalt's Avatar
nice work john but meh msrs lol if i had 5x114 i know i wouldnt be rocking those lol
Old Sep 17, 2011 | 10:59 PM
matt638's Avatar
this.
Old Sep 17, 2011 | 11:02 PM
haha hey but he must like em!
Old Sep 17, 2011 | 11:03 PM
ez mikey. #1 winter tires. and winter wheels. #2 you go find wheels at 4.30 on a Saturday afternoon with suitable winter tires for cheep. installed and balanced. that clear brembos.
his summer wheels will be different. its not california, its canaduh!
that is all
Old Sep 17, 2011 | 11:12 PM
MastaShaKe_88's Avatar
Best part an it looks purdy nice Good work
Old Sep 17, 2011 | 11:33 PM
that is all
haha oh ok well then its ok lol i run summer tires all year long like a baws john lol still debating if i wanna go with rs3 again tho or starspecs hmm
Old Sep 18, 2011 | 09:57 AM
californication dont have no winter. StarSpecs, but a pita u have to buy from Tire Rack exclusively
Old Sep 18, 2011 | 10:25 AM
06_cobalt's Avatar
That is awesome that we can get rid of our drums now lol. Powell how's the website coming along?
Old Sep 18, 2011 | 10:31 AM
not well all these jobs and parts are sucking up too much time
Old Sep 18, 2011 | 11:45 AM
D-mac's Avatar
Looks good John
Do you have access to LSJ Caliper Brackets and Calipers for a good deal?
Old Sep 18, 2011 | 03:52 PM
limited supply of used, dont recommend old used, plentiful supply of reman loaded calipers less pads, need cores...
Old Sep 18, 2011 | 03:58 PM
Raiden8816's Avatar
Little lost lol
So this 08 TC had 4x100 and was converted to disc, as it should have been from the factory.
Cool stuff...
Now I ask Mr Powell the drum to disc kit, do you have any for a 4x100? I am looking into getting discs for the rear but don't want to drop 2k for SSBC and am a little iffy on the Saturn SC rear disc swap
Old Sep 18, 2011 | 04:37 PM
2.2balt's Avatar
^its an LS with a SS kit on it, hence the look of a TC.
Very nice, and $225 starting for drum to disc swap is very good. Nice work all around
Old Sep 18, 2011 | 04:41 PM
padlock's Avatar
i have a feeling your wrong.. look at first pic.. LS's dont have rear discs.. oh wait, unless he previously had them converted.. man this guy must really like brakes
Old Sep 18, 2011 | 04:45 PM
Raiden8816's Avatar
Looks like my first mod for next year once my car is paid off
Old Sep 18, 2011 | 07:16 PM
2.2balt's Avatar
Urg please read the thread title....*facepalm @ U*
Old Sep 18, 2011 | 08:21 PM
Lol 2.2 balt I wit u!
its same year as yours, a 2.2 08. We did the rear disc conversion last week, but I was not satisfied with the caliper positioning. I had made it just like the race cars, dropping the caliper to the horizontal, but it makes the hand brake cable routing a little tight (still worked though) but for total package I decided to remake the brackets to stock postioning and that way I can use the stock disc dirt shields (which I forgot to put on while scurrying around trying to fix the wrong wheel bolt circle/find new wheels qwik problem)
The starting price is for the brackets to convert, you go get the rest of the parts. The pricing on the rest of the stuff is in the works, but I can say that I will probably do two complete rear kits for a very good price soon, as I have enough take off parts from race cars to make that up.
Tributes car was an 08 like I said, but the corrosion on his bearings was bad, and would take a lot of cleanup, and then you have to ask yourself if you want to invest in a kit using old parts. The re-drill of rotors to 4 x 100 is sort of dicey as you have to pilot off one existing hole in an LSJ rotor. The centering ring i make to facilitate the use of LSJ rotors on the smaller 4 x 100 bearing center, will not fit UNLESS you clean off ALL the corrosion on the bearing hub center and the face. Not a difficult job, just a pita .
The rear steel lines from GM are a "bulk line purchase make your own flares" which is difficult to ask a DYI'er to do, as the GM ball flare is not ez to make and takes a decent service tool to make.
Old Sep 21, 2011 | 05:36 AM
-TurboSS-'s Avatar
How much would the front brembo's and the hub conversion be for an 07 SS 2.4? Might not need to covert to a different bolt pattern though because they are re-issuing the rims I want to get apparently.
Remove SKU Name Price QTY Ext. Price
BBUK Brembo Brake Upgrade Kit for LSJ's BBUK $872.79 $872.79
SubTotal $872.79
Any cheaper then that? I'm assuming that is all that is needed... (CrateD prices)
06MetallicBalt
Jul 20, 2025 08:47 PM
Jan 12, 2016 12:01 AM
agentirons
Oct 16, 2015 02:11 AM
Sep 27, 2015 08:53 PM
roth
Sep 26, 2015 12:16 PM
