Unboxing the Powell rear axle bushing
Old 07-01-2015, 10:48 PM
  #51
yellowsupercharged06's Avatar
I can vouch for andrew, he is a great guy helped me out a ton!!
Old 07-02-2015, 10:05 PM
  #52
Powell Race Parts's Avatar
Thanks john thats great news about the tool. Is there a need to make anything bigger for the bigger cross pin. I think i saw something about the having to modify the bracket or is everything included like stated in the op?
You can drill out your own brackets for the larger pivot bolt or I can do it for you. Said good guy Andrew Carr just gave me a pair ; i drilled and will powder coat...I ran out of brackets, peeps never sent theirs back lol
Old 07-02-2015, 10:58 PM
  #53
Ok then i just have to make sure i need the bushings and i would like to get the brackets as well. And ill send you mine back
Old 07-06-2015, 07:18 PM
  #54
I'm old school
Halfcent's Avatar
Did you ever get the bushing clearance issue solved? Even on the replacement set you sent me, the bearing pin still sits below the height of the bushing, requiring bearing shims.
Old 07-07-2015, 08:14 AM
  #55
all the bearing sleeves are proud now. Machinists can screw up, I have a set mismatched came in the other day. Funny thing is, my set which are indentical to yours and a set in Grand Prairie Alberta are still good after four years of use. Not sure what the deal is. Warren said his were resolved with maintenance. So....
05-28-2022 03:47 AM
biniecki
10-25-2015 02:23 PM
DANRICKARD
10-01-2015 12:08 AM
nathan112i
09-30-2015 07:12 PM
Delta coupe
09-30-2015 08:11 AM
Quick Reply: Unboxing the Powell rear axle bushing
